It is currently Tue Aug 05, 2025 8:14 am
 Post subject: coil overs
PostPosted: Sun Jun 18, 2006 11:24 am
has anybody got them in there mini or know much about them?? what do u think of putting them in cause i not to sure i would like to but yer advice would help
PostPosted: Sun Jun 18, 2006 1:12 pm
i've seen them done, and i'd say unless you were building a space frame race car the rubber cones are just fine
PostPosted: Sun Jun 18, 2006 6:20 pm
its because i am putting 13inch rims on and i want i low as well and i thought there might be to much bounce in the rubber cones
PostPosted: Sun Jun 18, 2006 6:38 pm
no not too much bounce at all, the standard setup is pretty damn good, good enough to win rallies and track races.
we have 13's on our mini with hi-los, but we also have cut guards so we can run it fairly low, without cutting the guards you have to keep it fairly high or it will scrub.
the more you cut the lower you can go i guess but dont forget about the exhaust and the sump clearance
PostPosted: Sun Jun 18, 2006 7:55 pm
did u cut the rear guards
PostPosted: Sun Jun 18, 2006 8:15 pm
nope, the main problem is when the wheels scrape as you turn around a corner, the rear wheels dont turn so its ok.
before guards were cut, couldnt drive it at all
after guards were cut, still scraped on bumps and bumpy corners
after hilos were fitted
Users browsing this forum: Pottsy and 95 guests
