It is currently Mon Aug 04, 2025 12:42 pm
PostPosted: Sun Jun 18, 2006 4:11 pm
Hey all.
Does the Morris 1100 have the same motor, box etc as a mini?
Any other info on the 1100's would be much appreciated.
Azza
Life is like a giant cheese wheel...
Umm... I got nothin.
PostPosted: Sun Jun 18, 2006 4:16 pm
Motor is the same as used in Mini K and early Clubman 1098. But the engine mounting setup at fan end is different to a Mini and would need changing..
Gearbox is only 3 synchro though- basically same as a Mini Deluxe 998, except the remote shift is bolted on a bit different and it has a much shorter diff.
If you put into a Mini, pull the diff out first, and fit a 3.44 or a 3.65 instead of the 4.26? that it's got now. Morris 1100 had 12" wheels and BIG profile tyres.
PostPosted: Sun Jun 18, 2006 4:19 pm
Hey.
Thanks.
I actually wanted to know as I hoping to get the morris off poeee and wanted to know if the MINI motor would go into the morris. Lol.
Cheers for the quick answer.
Azza.
Users browsing this forum: No registered users and 120 guests
