Morris 1100 / Mini motor?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20268
Author:  Azza_Melb [ Sun Jun 18, 2006 4:11 pm ]
Post subject:  Morris 1100 / Mini motor?
Hey all.
Does the Morris 1100 have the same motor, box etc as a mini?
Any other info on the 1100's would be much appreciated.
Azza
Author:  drmini in aust [ Sun Jun 18, 2006 4:16 pm ]
Motor is the same as used in Mini K and early Clubman 1098. But the engine mounting setup at fan end is different to a Mini and would need changing..
Gearbox is only 3 synchro though- basically same as a Mini Deluxe 998, except the remote shift is bolted on a bit different and it has a much shorter diff.
If you put into a Mini, pull the diff out first, and fit a 3.44 or a 3.65 instead of the 4.26? that it's got now. Morris 1100 had 12" wheels and BIG profile tyres.
Author:  Azza_Melb [ Sun Jun 18, 2006 4:19 pm ]
Hey.
Thanks.
I actually wanted to know as I hoping to get the morris off poeee and wanted to know if the MINI motor would go into the morris. Lol.
Cheers for the quick answer.
Azza.
