It is currently Thu Jul 24, 2025 2:12 am
 Post subject: I shiatsued myself today
PostPosted: Mon Jun 19, 2006 5:21 pm
i was playing around with LORNA's (the mini) front today and noticed that the RHF bolt that goes thru the body to the subframe was, well GONE!!
so that is now on the to do list!!!
rather frightening knowing that your subframe is 1 bolt closer to falling out!!!
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Mon Jun 19, 2006 6:06 pm
:lol:
lucky you found it
PostPosted: Mon Jun 19, 2006 6:47 pm
You too - when I bought Henry, I took it back to work for the boss to give it a once over. He was all smiles until he looked at the front and saw BOTH of the bolts missing. Frightened me too but he assured me that whilst they are necessary, the engine steadys would stop the thing rocking about. However I went and bought some through bolts, nuts and washers and fixed it - more for peace of mind.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Mon Jun 19, 2006 7:48 pm
I've been told that some Clubmans came from the factory without the front subframe mount bolts. Not sure if that is true though, is there anyone else here missing both front subframe bolts? Maybe they're just the first ones to fall out!
PostPosted: Mon Jun 19, 2006 7:54 pm
Commonly missing on Mokes too.
Best replaced with nylocks :D
PostPosted: Tue Jun 20, 2006 9:57 am
But if you are driving a flying tent then you are not really concerned about sturdiness now are you? :wink: :D
PostPosted: Tue Jun 20, 2006 10:10 am
i though that they were mainly to hold the front panels to something sturdy, if you have a flip front, wouldnt it be the same as having the 2 bolts missing? i mean, you sub frame would not be just as secure
PostPosted: Tue Jun 20, 2006 10:54 am
Flip fronts have 2 braces going to the front of the subframe to stiffen it back up.
TENT !!! :x
I'll have you know we don't need such frivolities as enclosed cars over here :P
