It is currently Sun Jul 20, 2025 8:29 pm
PostPosted: Sat Jun 24, 2006 11:01 pm
Just been searching.. (THOUSANDS of results)
just one newbue-esque thing i'm not sure on...
it's oil out, isn't it?
what if i'm not taking the old seal out and just squashing the newies over the top?
PostPosted: Sat Jun 24, 2006 11:02 pm
and which manual is the procedure in...
i've got a haynes and a number 64..
PostPosted: Sun Jun 25, 2006 8:22 am
Oil out if you are taking the seal out too replace. I did one yesterday. You can just push one in over the top, but then you end up with another one stuffed in there. I had to pull two and a half of the the little buggers out of mine.
I would change the oils anyways. :D
PostPosted: Sun Jun 25, 2006 11:34 am
i was just gona chuck the two i have in on top...
may aswell change the oil :)
PostPosted: Sun Jun 25, 2006 11:37 am
I think the most I have seen was 5 on top of each other and all leaking horribly .... Have a chat to Matt (theminiman) about his super dooper o-ring seals , much better system .
PostPosted: Sun Jun 25, 2006 11:39 am
meh.. i've got two seals anyway and i'm busting to do something in the garage at a last :)
PostPosted: Sun Jun 25, 2006 11:43 am
Yeah , go for it ..... But why has Astro been corrupted and fitted with a rod change ????? Oh the horror of it all , won't somebody please think of the children ..... Ahem , ok , simpsons flashbacks there :roll:
PostPosted: Sun Jun 25, 2006 11:50 am
astro was fitted with a 1098'd 998 :)
how's that for horror...
if i manage to get this cooper i've heard about, i'll most definitely put an 850 back in, change the wheels back and take off the flares..
then on goes the visor! :D
PostPosted: Sun Jun 25, 2006 11:58 am
That sounds good , let Astro age gracefully rather than pimping him up like a grandmother in Lycra mumble pants :shock: :shock: :shock:
Users browsing this forum: Scoop and 83 guests
