It is currently Sat Jul 19, 2025 2:23 pm
 Post subject: Find of the Day
PostPosted: Sat Sep 25, 2004 5:49 pm
I have just discoved a treasure trove called the Reverse Garbage Warehouse. I picked up two pieces of foil backed foam with the lead sound deadening layer in the foam.
One piece is 1.2 m x 150mm and the other is 1.6m x 280mm The foam as I said is Foil on one surface about 25mm thick and the layer of lead deadening stuff about 8mm from the foil face. All for $11 :shock:
Also got two half height steel panel cases suitable for some amplififers I'm building Full of electronic stuff I haven't fathomed yet but they were $9.50 each - the cases empty on their own are $70 each in the electronics shops :wink:
Oh by the way I went looking for some MDF off cuts - they didn't have any :lol:
PostPosted: Sat Sep 25, 2004 6:07 pm
Thats Cheeeeep Wombat well done
PostPosted: Sat Sep 25, 2004 7:37 pm
sounds like a good find. where abouts is this place?
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Sat Sep 25, 2004 9:11 pm
For the Brizzy people http://www.reversegarbage.com.au/index.htm
PostPosted: Sat Sep 25, 2004 9:47 pm
There's one in Sydney too, at Casula. :wink:
