It is currently Sat Jul 19, 2025 8:50 pm
 Post subject: Try or leave it
PostPosted: Thu Sep 23, 2004 9:19 pm
well one of our minis has no brakes
has recently probably only about 600kms ago had it all done - new wheel cylinders, brake cylinders , drums, shoes etc but now it doesnt stop no brake pedal at all
SO i assume its the brake master cylinder should i attempt taking this out of the car taking it to get rebuilt then putting it back on
Whats the deal is this strictly a job for the pros or could i pull it off
:roll:
PostPosted: Thu Sep 23, 2004 9:33 pm
U can get it out yourself, but you will need a pair of long pointy nose pliers. Take the two bolts holding it in, out. Disconnect the brake line.
Take out the Drivers seat, get a light and crwal upside down into the foot well. Use the Long pointy nose pliars to remove the split pin from the clevis pin. Then remove the cleavis pin. Climb back out and pull out the clutch cylinder. If you can't pull it out. you have removed the brake master cylinders cleavis pin. That's when you can swear and curse....
Aaron
PostPosted: Thu Sep 23, 2004 9:37 pm
Maybe I read it wrong......
Aaron, if he is trying to take the brake master cylinder out, why would he remove the clutch master cylinder?
PostPosted: Thu Sep 23, 2004 9:38 pm
but i want to take the brake master cylinder out not the clutch
PostPosted: Thu Sep 23, 2004 10:02 pm
i had no pedal
it ended up being a line had a split in it, non visible but when i pumped the pedal someone watching could see fluid coming out = no pedal at all.
replace it
check for that first rather than spending the $$$ on ur master cylinder
PostPosted: Thu Sep 23, 2004 10:12 pm
i dont seeem to be losing brake fluid though i will check for that tommorow but im pretty sure its the BMC
i cant think of what else it could be
how hard is it to take off and put back on im a little worried about bleeding the brakes never done this before
PostPosted: Thu Sep 23, 2004 10:14 pm
I agree with 850pvan, Find the problem first and then fix what is wrong don't fix the master cylinder and then find a loose pipe on a rear wheel cylinder or a bleeder that is undone.
Is the master cylinder full of fluid?
If not where has the fluid gone?
Is there a puddle of fluid under the car?
Is there a puddle of fluid on the drivers floor?
Are the brakes adjusted?
PostPosted: Thu Sep 23, 2004 10:39 pm
ok from what i can tell this is what is going on
the whole car was recond pretty much except the brake master cylinder and a few other things
there was a fair amount of money spent on the brakes new wheel cylinders brake cylinders shoes drums and they had a good hard peddal but when i was driving a few times it did something weird
i pushed the peddal and went all the way to the floor without stopping the caer it has a little bit of stopping power just as you push the peddal a little pump the peddal near the top of its travel however after this nothing
There IS FULL Brake Fluid
Can not see Leaking Under the Car
It just went all of a sudden within a space of about a day
:cry:
just wondering if it is realistically something that can be taken on at home
PostPosted: Fri Sep 24, 2004 12:42 am
you certainly should be able to do it yourself mate....mini brakes aren't the most complicated things around
the symptoms you;ve described are VERY weird sounding :? so i'm not gonna lie and say i might know what it is......just check everything over. Like i said, mini brakes aren't terribly complicated. Good luck
play 3d car games for free
PostPosted: Fri Sep 24, 2004 7:31 am
3 Points.
1 Don't drive the Car.
2 Call the idiot that did it for you
3 I don't think think this but it may just need ajusting.
As per the adove replies check for any leaks and take the wheels off and the drums and look inside. Make sure all springs are fitted and shoes are in thier corrct spots.
Drum brakes need to be ajusted. Seen as you have only done 600klms they will need ajusting but not to the extent of no brake pedal.
It may be the master cyclinder and can be done you'reself as per the first reply but when you're upside down in the foot well go for the one on your the left. The brakes will need bleeding after not really that hard.
Last thing. Do you find you have you have brakes when the Hand brake on :?:
Cheers let us know how you get on :arrow: :D
PostPosted: Fri Sep 24, 2004 8:40 am
yes well, you would be right there, but when i did it, i was pulling out the clutch, of course i pulled the brake one out... i was retelling what happened to me. Sorry.
PostPosted: Fri Sep 24, 2004 8:44 am
LoL aaron Bugger :lol:
PostPosted: Fri Sep 24, 2004 9:09 am
yeah thanks guys i will give it a good look this today and over the weekend
the guy who did it is in Bundaberg and im in Brisbane sooooot i cant take it back easily but i dont think it was his fault anyways as theres no pedal at all the handbrake still works as normal
PostPosted: Fri Sep 24, 2004 9:18 am
Where in Brizzy are you?
David L
Handbrake works as normal does the peddel feel firm when the handbrake is on.
I do think its in the line. Could be one of the nipples :oops: could be a little lose
What ever happens you will need to Bleed the brakes :?
Users browsing this forum: No registered users and 69 guests
