It is currently Fri Aug 15, 2025 3:33 pm
PostPosted: Tue Jun 27, 2006 9:08 pm
Hi all!
Driving home tonight and realise my tailights arnt working.
I have all other lights, including rear brake lights, and rear blinkers. I also have both headlights and parkers.
What may be the problem?
ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Jun 27, 2006 9:10 pm
fuse?
 Post subject: Firewall
PostPosted: Tue Jun 27, 2006 9:14 pm
Brake switch???
PostPosted: Tue Jun 27, 2006 9:15 pm
Brake lights still work so dont see why that would casue a prob?
And wouldnt the fuse for the rear lights be the same as all the others?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Tue Jun 27, 2006 9:33 pm
Fixed. Well almost.
Was just a wire that came off. I will fix in the morn. Need a new spade conector.
ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Tue Jun 27, 2006 9:40 pm
Ryan
do the number plate lights work? If so and as you say the parkers work, then it would seem a simple problem of blown light bulbs. Otherwise it may be a faulty earth connection in the boot or a wiring problem in the loom feeding the rear lights. As long as you have a wiring diagram for the right model and the colour identifications, the problem should be easy to find.
David
Users browsing this forum: No registered users and 407 guests
