It is currently Wed Jul 23, 2025 2:39 am
 Post subject: Just cant get it off!
PostPosted: Mon Jun 26, 2006 4:21 pm
ausmini mod
ausmini mod
Hi,
So I began door trims yesterday and first plan of attack was to remove the existing trim and use as a template.
Well, sounds easy... BUT... how the heck do I get the Window Winder off... its stuck and wont budge. (Rusted on probably?) :evil:
I put a screwdriver behind it, and tried to pry it off... nope... nothing.
My old man reckons I can buy a tool that is like a claw (similar to a flywheel puller I guess) to get things off but I dont want to yet.
Anyone got any ideas? WD-40 the shite out of it and let it sit overnight??
Any other ideas?
Thanks,
Peter.
PostPosted: Mon Jun 26, 2006 5:31 pm
Try taking two rubber hammers ($2.00 at the junk shops) and hitting the winder from each side at the same time.. That should do the trick..
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
 Post subject: Its OFF!!!!
PostPosted: Thu Jun 29, 2006 5:16 pm
ausmini mod
ausmini mod
Haha - Its off!!!!
OK, so I grabbed the WD-40 (it solves everything :) )
I sprayed it absolutely all over the winder and behind it...
Then I bashed the winder with a hammer.
Nope, still stuck.
So I tried 2 rubber mallets... nope, still stuck.
Time for brute force...
I get TWO hammers (normal with claw on the back) and wedged them behind the winder.
I pulled and jiggled until the bastard came off!
Now its off and getting cleeeeeaaaaannned and sanded before going back on... HAH you little scummy winder - I WIN!
Peter.
