You may as well set up the dellorto from the start, the running in will be the easiest the motor gets treated as you may rev it a bit but won't be doing a lot of high speed stuff, you might like to increase the choke size for the bigger engine and may need to go a little bigger in the idles to start with, i have some 32 mm chokes here if you need them you can have em free as they are just gathering dust here
Jon
