Just cant get it off!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20547
Author:  pristic [ Mon Jun 26, 2006 4:21 pm ]
Post subject:  Just cant get it off!
Hi,
So I began door trims yesterday and first plan of attack was to remove the existing trim and use as a template.
Well, sounds easy... BUT... how the heck do I get the Window Winder off... its stuck and wont budge. (Rusted on probably?) :evil:
I put a screwdriver behind it, and tried to pry it off... nope... nothing.
My old man reckons I can buy a tool that is like a claw (similar to a flywheel puller I guess) to get things off but I dont want to yet.
Anyone got any ideas? WD-40 the shite out of it and let it sit overnight??
Any other ideas?
Thanks,
Peter.
Author:  DJG-14U [ Mon Jun 26, 2006 5:31 pm ]
Try taking two rubber hammers ($2.00 at the junk shops) and hitting the winder from each side at the same time.. That should do the trick..
Author:  pristic [ Thu Jun 29, 2006 5:16 pm ]
Post subject:  Its OFF!!!!
Haha - Its off!!!!
OK, so I grabbed the WD-40 (it solves everything :) )
I sprayed it absolutely all over the winder and behind it...
Then I bashed the winder with a hammer.
Nope, still stuck.
So I tried 2 rubber mallets... nope, still stuck.
Time for brute force...
I get TWO hammers (normal with claw on the back) and wedged them behind the winder.
I pulled and jiggled until the bastard came off!
Now its off and getting cleeeeeaaaaannned and sanded before going back on... HAH you little scummy winder - I WIN!
Peter.
