Lockable Fuel Tank Caps https://www.ausmini.com/forums/viewtopic.php?f=2&t=2057 |
Author: | 68matic [ Sun Sep 26, 2004 4:43 pm ] |
Post subject: | Lockable Fuel Tank Caps |
hey everyone i got a $3 lockable fuel tank cap looks just like the ones at the shops for $20 BEWARE make sure you test the key and turn it make sure that the locking pins actually move out of the way to be removed mine werent moving all that much so i had to stick a screwdriver in it and turn until things went click and gurgle no, nothing fell in the tank, thats the sounds of $3 being washed down the drain |
Author: | Anto [ Sun Sep 26, 2004 4:49 pm ] |
To be honest I prefer the more expensive genuine ones because I don't have that worry about losing half the cap inside the petrol tank! And even though it is a Mini, you can't just turn it upside-down and shake it! ![]() |
Author: | 68matic [ Sun Sep 26, 2004 5:15 pm ] |
i think this was actually one of those $20 ones i had seen at the shops this was second hand at a market anyhow, with ALL of them, check first |
Author: | drmini in aust [ Sun Sep 26, 2004 6:44 pm ] |
I'd settle for a couple that don't ******' leak.... ![]() The ones that seal on the outside are useless if the neck top is distorted, like 99% of Mini ones are... from people butchering locking caps off.. ![]() |
Author: | Namibian CAMEL [ Mon Sep 27, 2004 8:42 pm ] |
What other types of mini fuel caps were there anyway???? |
Author: | drmini in aust [ Mon Sep 27, 2004 9:00 pm ] |
Originals were `push in and turn', bit like a radiator cap. Non locking. They sealed better. But people didn't go around siphoning tanks back then! ![]() |
Author: | Lillee [ Mon Sep 27, 2004 11:11 pm ] |
drmini in aust wrote: But people didn't go around siphoning tanks back then!
![]() Or Worste! now that we're on this topic, mine is rusty on the inside (which describes most of my car... ![]() ![]() ![]() ![]() ![]() |
Author: | J_A_M [ Mon Sep 27, 2004 11:23 pm ] |
Same here Chong. I am still undecided what to do. Was thinking agout this: Fuel Tank Repair Kit I hear the motorbike tank kit is OK for a Mini.... ![]() |
Author: | Mike [ Tue Sep 28, 2004 3:49 am ] |
drmini in aust wrote: I'd settle for a couple that don't ******' leak....
![]() The ones that seal on the outside are useless if the neck top is distorted, like 99% of Mini ones are... from people butchering locking caps off.. ![]() Is there a mod to cure the leaks? Like creating a silastic or sikaflex gasket around the lip? |
Author: | drmini in aust [ Tue Sep 28, 2004 6:42 am ] |
One way would be buy some Aston- type flip caps, these go over (or into?) the tank neck and could be sealed to it properly with Araldite or similar. But, good ones from UK cost $$$.... and people would probably try to knock them off too.. ![]() |
Author: | gafmo [ Tue Sep 28, 2004 6:57 am ] |
drmini in aust wrote: One way would be buy some Aston- type flip caps, these go over (or into?) the tank neck and could be sealed to it properly with Araldite or similar.
But, good ones from UK cost $$$.... and people would probably try to knock them off too.. ![]() I have one of these on Sue's Morris ![]() ![]() |
