TAIL LIGHTS NO WORKIE! WHY? https://www.ausmini.com/forums/viewtopic.php?f=2&t=20594 |
Author: | ryan [ Tue Jun 27, 2006 9:08 pm ] |
Post subject: | TAIL LIGHTS NO WORKIE! WHY? |
Hi all! Driving home tonight and realise my tailights arnt working. I have all other lights, including rear brake lights, and rear blinkers. I also have both headlights and parkers. What may be the problem? ryan |
Author: | aussie [ Tue Jun 27, 2006 9:10 pm ] |
fuse? |
Author: | 9YaTaH [ Tue Jun 27, 2006 9:14 pm ] |
Post subject: | Firewall |
Brake switch??? |
Author: | ryan [ Tue Jun 27, 2006 9:15 pm ] |
Brake lights still work so dont see why that would casue a prob? And wouldnt the fuse for the rear lights be the same as all the others? Ryan |
Author: | ryan [ Tue Jun 27, 2006 9:33 pm ] |
Fixed. Well almost. Was just a wire that came off. I will fix in the morn. Need a new spade conector. ryan |
Author: | 64cooper [ Tue Jun 27, 2006 9:40 pm ] |
Ryan do the number plate lights work? If so and as you say the parkers work, then it would seem a simple problem of blown light bulbs. Otherwise it may be a faulty earth connection in the boot or a wiring problem in the loom feeding the rear lights. As long as you have a wiring diagram for the right model and the colour identifications, the problem should be easy to find. cheers David |
