It is currently Sat Aug 02, 2025 9:49 pm
PostPosted: Fri Jun 30, 2006 7:47 pm
hi guys, on my way home I lost my bracke pressure. I havejust got new lines fitted yesterday, new rear pads, all was working great till my trip home, I felt a strange feeling through the brake peddle then no pressure ( Ie all the way to the floor with very little effect) any ideas< I have checked no brake fluid under the car, still has some in the can, ( about the same as my clutch)
thanks Brett
PostPosted: Fri Jun 30, 2006 7:48 pm
oh, it's on my 1967 Cooper S
PostPosted: Fri Jun 30, 2006 7:49 pm
brake master cylinder needs rekitting???
PostPosted: Fri Jun 30, 2006 8:03 pm
brake adjusters need to be adjusted?
PostPosted: Fri Jun 30, 2006 8:08 pm
Maybe the pin has come out that connects the pedal to the plunger?
PostPosted: Fri Jun 30, 2006 8:12 pm
bet 10 bucks on brake master cyllinder
PostPosted: Fri Jun 30, 2006 8:16 pm
Lift carpet under pedals, check for fluid there.... :cry:
If so, rekit M/C or replace with a new one.
PostPosted: Fri Jun 30, 2006 8:40 pm
take it back
PostPosted: Fri Jun 30, 2006 9:41 pm
Sounds like pin falling out to me.
PostPosted: Fri Jun 30, 2006 10:49 pm
taking it back tommorrow and they can hold it at the garage tommorrow and over the weekend. Funnily enough I was just commenting to my father how good the brakes felt since the service. oh well have to go make to the New MINI :lol:
PostPosted: Sat Jul 01, 2006 8:56 am
if they stuffed it they fit it...specialy when it has to do with Brakes.
don't risk your life or others
PostPosted: Sun Jul 02, 2006 1:10 am
i have found in the past that if they stuffed they will stuff it again
ive had similar probs with mechs and mini brakes dont know why maybe just my case
find a mini specialist and a good one and stick with him is what ive learnt
PostPosted: Sun Jul 02, 2006 6:32 pm
yep 530km away :cry: :cry:
PostPosted: Mon Jul 03, 2006 9:43 pm
That's my current problem/symptoms - need a new master cylinder (and consarnit no-one is ever open when I have time to go there!). There's no really obvious leak, but it's always damp around it, and I came to that conclusion after fixing everything else.
Users browsing this forum: fuzzy-hair-man and 93 guests
