Reversing light switch
https://www.ausmini.com/forums/viewtopic.php?f=2&t=2071
Author:  Drekkus [ Mon Sep 27, 2004 3:48 pm ]
Post subject:  Reversing light switch
I've been looking for a reversing light switch for my remote change gearbox and today I found a mini at the wreakers with one on it.
I eventually managed to get it off and now I have a switch and a spring but did I miss something as I don't see how these two parts by themselves will work.
Author:  drmini in aust [ Mon Sep 27, 2004 4:00 pm ]
Simple- when you select reverse, the lockout plunger comes up, and closes the switch.. :wink:
The spring is just the lockout for reverse. I put a nice `red die spring' in there instead, so it's harder to get the reverse gate by mistake- when you really wanted 3rd gear.. 8) ..
Author:  Drekkus [ Mon Sep 27, 2004 6:24 pm ]
Thanks for that.I didn't want to have to go back as with the front end the way it was it wasn't easy to get to.
I put the switch on and it didn't work.I've ended up having to add a small length of 5mm steel rod into the spring and now it works perfectly.
