It is currently Sun Jul 20, 2025 7:57 am
 Post subject: brakes bleeding
PostPosted: Sun Jul 02, 2006 1:43 pm
possibly stupid question but why arent there brake bleader valves on the front brakes? Or are there and I just can't find them..or do you just bleed them from the back?
thanks
 Post subject: Re: brakes bleeding
PostPosted: Sun Jul 02, 2006 2:05 pm
thanks
Disks or Drums :?:
Assuming drums....go out and have another look...say passengers side, to the right of the drum at the back....you will see a pipe coming in and the bleeder is above that pointing up at an angle.
PostPosted: Sun Jul 02, 2006 2:08 pm
yes drums... cheers for that 9YaTaH
PostPosted: Sun Jul 02, 2006 2:23 pm
Start back passenger side (furthest away from master) and work your way towards the master cylinder, for best results.
PostPosted: Sun Jul 02, 2006 4:56 pm
turned out there was a leak in one of the pipes so that needs to be replaced before the brakes will work :cry:
 Post subject: Lines
PostPosted: Sun Jul 02, 2006 5:14 pm
If the pipe is rusted through...then replace the lot....the chances are they will all be in the same condition....take yours as samples to a brake place and they will make them up for you :idea:
 Post subject: Re: Lines
PostPosted: Sun Jul 02, 2006 5:18 pm
they arent actuall too bad..it was just the connection of one of the hoses - the bolt was slightly threaded and there was fluid leaking from there.
