brakes bleeding
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20733
Author:  aussie [ Sun Jul 02, 2006 1:43 pm ]
Post subject:  brakes bleeding
possibly stupid question but why arent there brake bleader valves on the front brakes? Or are there and I just can't find them..or do you just bleed them from the back?
thanks
Author:  9YaTaH [ Sun Jul 02, 2006 2:05 pm ]
Post subject:  Re: brakes bleeding
thanks
Disks or Drums :?:
Assuming drums....go out and have another look...say passengers side, to the right of the drum at the back....you will see a pipe coming in and the bleeder is above that pointing up at an angle.
Author:  aussie [ Sun Jul 02, 2006 2:08 pm ]
yes drums... cheers for that 9YaTaH
Author:  mooman10_0 [ Sun Jul 02, 2006 2:23 pm ]
Start back passenger side (furthest away from master) and work your way towards the master cylinder, for best results.
Author:  aussie [ Sun Jul 02, 2006 4:56 pm ]
turned out there was a leak in one of the pipes so that needs to be replaced before the brakes will work :cry:
Author:  9YaTaH [ Sun Jul 02, 2006 5:14 pm ]
Post subject:  Lines
If the pipe is rusted through...then replace the lot....the chances are they will all be in the same condition....take yours as samples to a brake place and they will make them up for you :idea:
Author:  aussie [ Sun Jul 02, 2006 5:18 pm ]
Post subject:  Re: Lines
they arent actuall too bad..it was just the connection of one of the hoses - the bolt was slightly threaded and there was fluid leaking from there.
