Is there a gasket for the tank filler recess on a mini van?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20734
Author:  Bromley [ Sun Jul 02, 2006 2:05 pm ]
Post subject:  Is there a gasket for the tank filler recess on a mini van?
Between the recess and the body panel
Also, is there a rubber that goes around the kneck that sits on the inside of the van parcel shelf?
A photo of someone elses van will be helpfull.
Author:  9YaTaH [ Sun Jul 02, 2006 2:14 pm ]
Post subject:  Could be....
Sealing ring, neck to floor is shown in the Mini Car Clinic cattledog...just a fat rubber donut by the looks of it. Then there is a fuel neck sealing gasket which looks like it presses in to the metal "pocket" where the filler comes out.
Author:  Bromley [ Sun Jul 02, 2006 5:24 pm ]
I have both of those. Just wondered if there was a gasket between the "pocket" and the body panel.
Author:  simon k [ Sun Jul 02, 2006 5:41 pm ]
even if there isn't meant to be one, I'd be making one out of plastic - cut one out of a black oil container, but I have a feeling there is supposed to be a cork one
Author:  Bromley [ Sun Jul 02, 2006 7:11 pm ]
Already put in place without the gasket :(
Author:  simon k [ Sun Jul 02, 2006 8:37 pm ]
did you use any sealant or anything?
Author:  Bromley [ Sun Jul 02, 2006 9:17 pm ]
No. Should I squirt some silicone behind it?
Author:  bnicho [ Sun Jul 02, 2006 9:26 pm ]
I've pulled apart quite a few vans and a traveller. They all just had a smear of seam-sealer in that join. I doubt the factory ever put a gasket in there.
Author:  DOZ [ Sun Jul 02, 2006 9:40 pm ]
My van had a thin cork/cardboard gasket from memory. After it got painted I used a bead of silicone that I wiped clean with turps after pushing the filler thing on, never had any leaks and it was super sexy hot looking :D
Author:  simon k [ Mon Jul 03, 2006 9:22 am ]
I reckon you should have something to seal it - the metal will move a bit, so it could rub through the paint, then if water gets in there....
PM Steve & Mikey and find out what they did with Bruizer
