It is currently Fri Aug 01, 2025 1:40 am
 Post subject: Oil pressure
PostPosted: Mon Jul 03, 2006 1:39 pm
I've got a Mini K. Goes quite well, but if I have a longer run at 100kph, when I then come to idle speed (it always idles quite slow, ie maybe 500RPM) the oil pressure drops to about 50 PSI where as it is normally 60-70 PSI at idle. What is the likely cause? It has no disturbing bearing noises.
Ta
Martin Dwyer
PostPosted: Mon Jul 03, 2006 1:42 pm
Quite Normal as far as I know.
My last clubbie dropped abnormally though after a long run. Went from 60-70 to about 30.
No more Minis!......For now.
PostPosted: Mon Jul 03, 2006 6:41 pm
thats not bad mine used to drop to about 30 psi when it idle.
PostPosted: Mon Jul 03, 2006 8:59 pm
Nothing wrong with that oil pressure after a high speed run.
 Post subject: Re: Oil pressure
PostPosted: Mon Jul 03, 2006 9:04 pm
Ta
Martin Dwyer
Sounds fine Martin....check us out at the website...Cheers, Mick
