Oil pressure https://www.ausmini.com/forums/viewtopic.php?f=2&t=20755 |
Author: | Martin Dwyer [ Mon Jul 03, 2006 1:39 pm ] |
Post subject: | Oil pressure |
I've got a Mini K. Goes quite well, but if I have a longer run at 100kph, when I then come to idle speed (it always idles quite slow, ie maybe 500RPM) the oil pressure drops to about 50 PSI where as it is normally 60-70 PSI at idle. What is the likely cause? It has no disturbing bearing noises. Ta Martin Dwyer |
Author: | Maxi23 [ Mon Jul 03, 2006 1:42 pm ] |
Quite Normal as far as I know. My last clubbie dropped abnormally though after a long run. Went from 60-70 to about 30. |
Author: | Stuartminidlx [ Mon Jul 03, 2006 6:41 pm ] |
thats not bad mine used to drop to about 30 psi when it idle. |
Author: | 64cooper [ Mon Jul 03, 2006 8:59 pm ] |
Nothing wrong with that oil pressure after a high speed run. |
Author: | 9YaTaH [ Mon Jul 03, 2006 9:04 pm ] |
Post subject: | Re: Oil pressure |
Martin Dwyer wrote: I've got a Mini K. Goes quite well, but if I have a longer run at 100kph, when I then come to idle speed (it always idles quite slow, ie maybe 500RPM) the oil pressure drops to about 50 PSI where as it is normally 60-70 PSI at idle. What is the likely cause? It has no disturbing bearing noises.
Ta Martin Dwyer Sounds fine Martin....check us out at the website...Cheers, Mick |
