It is currently Sat Aug 02, 2025 8:24 pm
 Post subject: Long tie rod ends
PostPosted: Mon Jul 03, 2006 6:47 pm
Will I need a set for my 8.4" Metro vented disk setup?
If not what are they used for?
PostPosted: Mon Jul 03, 2006 7:21 pm
Commonly used when fitting adjustable camber bottom arms...
I believe Triumph Spitfire ones will fit too, but Kc sells the longer ones for Minis.
PostPosted: Mon Jul 03, 2006 7:22 pm
part # ---> GSJ158
PostPosted: Mon Jul 03, 2006 7:43 pm
Kc's p/no is GSJ734#
$39.95 each.... ouch!!
Stock length ones are only $14.45.... :lol:
PostPosted: Mon Jul 03, 2006 8:54 pm
Matt
didn't know you could get longer tie rod ends Always thought that the way to pick up the extra length was to use the thick type steering arm to gain .24" on the thread of the tie rod.
PostPosted: Mon Jul 03, 2006 9:35 pm
Vizard suggests welding a nut onto the tie rod end to get more thread, but that's a pretty dodgy way to do it (and now illegal, probably).
