Clutch noise https://www.ausmini.com/forums/viewtopic.php?f=2&t=2082 |
Page 1 of 2 |
Author: | kiwi1275 [ Tue Sep 28, 2004 6:44 am ] |
Post subject: | Clutch noise |
Hi all My clutch has started making a squeaking noise when depressed, sounds like there are a flock of sparrows under the bonnet. I am guessing it is something bad, anybody had anything similar? Cheers Stu |
Author: | drmini in aust [ Tue Sep 28, 2004 6:53 am ] |
Clutch release bearing. Can be fixed in the car. Use a good UK-made bearing (RHP)- the cheap jap bearings are a POS (3 weeks, I got from the last one I used) ![]() |
Author: | gafmo [ Tue Sep 28, 2004 7:17 am ] |
RHP ![]() |
Author: | drmini in aust [ Tue Sep 28, 2004 7:43 am ] |
gafmo wrote: RHP
![]() RHP = RansomeHoffmanPollard- UK bearing maker. Their bearings can be got from any bearing supply house, they also come in the Borg & Beck (and probably Unipart) clutch kits. ![]() If release bearing doesn't have `made in England' on it I won't buy it any more. |
Author: | cush [ Tue Sep 28, 2004 4:48 pm ] |
i'm glad.... i'm about to get the borg and beck kit ![]() |
Author: | thommo09 [ Tue Sep 28, 2004 6:23 pm ] |
yeah mine just started maiing that noise the other day....wondered what it was maybe we should have a clutch-bearing-fix-it-up day cush ![]() ![]() |
Author: | cush [ Tue Sep 28, 2004 6:25 pm ] |
i was just going to send mine to the pros ![]() |
Author: | thommo09 [ Tue Sep 28, 2004 10:00 pm ] |
fair enuf i spose.... ![]() speaking of doing the job yourself.....is it a hard job for a novice (like myself) to do? or does cush have the right idea in sending it to the pros? |
Author: | drmini in aust [ Tue Sep 28, 2004 10:09 pm ] |
Release bearing job is real easy, once you get all the bolts out of the clutch cover. Bottom 2 are tricky. I use a 1/2" ring/OE spanner with the ring end heated and bent to 45*. Works for me... ![]() |
Author: | thommo09 [ Tue Sep 28, 2004 10:13 pm ] |
and its in the black book? how long do they usually last? cos i had a new clutch etc put in about a year and a half ago..... ![]() ![]() |
Author: | drmini in aust [ Tue Sep 28, 2004 10:28 pm ] |
Would be in the book- just stop `clutch dismantling' once you have the cover off. ![]() How long is a piece of string- it should last for years if you don't ride the clutch at the lights or rest your foot on it... ![]() Maybe you've got one of the cheapo jap bearings in there...! |
Author: | cush [ Wed Sep 29, 2004 10:02 am ] |
i was giving it to the pros beacause i'm not enritrely sure what the problem is and it's a case of.. "while you're in there...." ![]() plus, i get the satisfaction of not arsing it up |
Author: | thommo09 [ Wed Sep 29, 2004 10:57 am ] |
well i havent been riding the clutch or resting my foot on it.......but my engine mounts are on the way out so i've been VERY gentle on gearchanges for a few months now..... ahh well, i'm guessing just doing the bearing isnt too expensive either is it? |
Author: | cush [ Wed Sep 29, 2004 11:00 am ] |
the part is bugger, if i remember, so it's all labour... |
Author: | Anto [ Wed Sep 29, 2004 11:09 am ] |
drmini in aust wrote: Release bearing job is real easy, once you get all the bolts out of the clutch cover. Bottom 2 are tricky. I use a 1/2" ring/OE spanner with the ring end heated and bent to 45*.
Works for me... ![]() You heated your spanner?? I bought a $1 Super Cheap spanner, just bent it in a vice ![]() The annoying part is that I have lost my custom spanner for clutch end covers, and I'm up for a bearing replacement again! |
