Rear parcel shelf replacement
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20820
Author:  Flying Brick [ Wed Jul 05, 2006 11:38 am ]
Post subject:  Rear parcel shelf replacement
Gday, I was just wondering if anyone has replaced the rear parcel shelf on their mini, also are they available as new replacement panels or would i need a donor one. I want to put rear seat belts in my Mini K and the shelf has been cut for speakers as usual and the holes are right where i want to put the seatbelt mount. Any info would be great.
Thanks
Steve.
Author:  MINIRO [ Wed Jul 05, 2006 12:08 pm ]
I was going to post the exact same thing....
So yes any info on this would be great!!!!
Rohan
Author:  9YaTaH [ Wed Jul 05, 2006 12:12 pm ]
Post subject:  Re: Rear parcel shelf replacement
Thanks
Steve.
Steve...why not reinforce and patch the panel..make it stronger than a new replacement :idea: :?: :)
Author:  DJG-14U [ Wed Jul 05, 2006 12:14 pm ]
I dont think you can buy them as replacement panels. Well I have never seen them available anyway.
Besides if you was to replace it yourself or have anyone do it. I would suspect that it would need to be engineered..
Common problem with the metal being cut out by vandals... I think the next best thing would be to try and get a sheet of steel made up and then mig weld it in place. Also if you are planing to mount seatbelts it might be an idea to put another piece of thick plated metal where you intend on mounting the belts.
Might even be best to speak to someone from one of those safety restrant fitting stations as to what to do...
Author:  Flying Brick [ Wed Jul 05, 2006 12:27 pm ]
Thanks, if i do it, it will be stronger than the original mountings which aren't great. Mick, I might have to make up a panel as you said and weld in place, just thought it would be easier to get a new one.
Steve.
Author:  Flying Brick [ Wed Jul 05, 2006 1:34 pm ]
I was just talking to a panel beater friend and he has told me it isn't a good idea to weld in a made up sheet onto the old shelf. This is part of the crumple zone and strengthening it could be dangerous in an accident. He suggested just make up a piece of sheet metal to cover the speaker hole and weld in place from the underside.
Any more information from people really appreciated.
Steve.
Author:  pristic [ Wed Jul 05, 2006 1:39 pm ]
Did crumple zones exist in Mini's?? I didnt think so... the bit that gets hit usually crumples :lol:
Author:  Mick [ Wed Jul 05, 2006 1:47 pm ]
The crumple zone starts at the front bumper and should see you comfortably seated in the back seat after a crash :wink:
Author:  DJG-14U [ Wed Jul 05, 2006 1:51 pm ]
Well to be honest I think the Mini would bounce before it crumpled :)..
Mainly because back in the old days they made real cars unlike the plastic hi tech junk on the roads today. Further more that is why you will probably still see Mini's on the road in another 40 years where as the plastic high tech junk would have been recycled 5 times over into plastic shopping bags.
Just my Image anyway :).
Author:  drmini in aust [ Wed Jul 05, 2006 8:01 pm ]
Trust me guys, Mick is not kidding... I once spent 3 hours `uncomfortably seated' there (and trapped) before they cut me out... :lol: :x
re the parcel tray- go look at a late Clubby that has the rear belts, you will see how they reinforced it.
I doubt you will buy a new Oz panel and I bet the UK ones are different.
Author:  willy [ Wed Jul 05, 2006 8:04 pm ]
What a load of crap that 'panel beater' was spinning..
Author:  Flying Brick [ Thu Jul 06, 2006 7:44 am ]
Hmmmmm, thanks for your input willy. But he is someone I know well and respect, he does know what he is talking about and would definately know more than you about it. I wasn't going to reply to you but when you say silly things like that i just had to. I dont know you ,so i am not making any judgements of you but those things don't need to be said.
Steve.
Author:  9YaTaH [ Thu Jul 06, 2006 8:22 am ]
Post subject:  shelved
Steve....I really think you need a second opinion....the parcel shelf is an integral part of the body construction and it provides a lot of strength in that area.
If it has had part of its flat panel section cut....then all it needs is that part patched and as the Doc (n me) says check out some reinforcing (some clubbies had rear seat belts).
Respect is one thing....familiarity with 40 year old British cars is another :idea:
Author:  JC [ Thu Jul 06, 2006 8:29 am ]
I have the same issue, I was just going to weld a replacement piece into the holes.
Author:  Flying Brick [ Thu Jul 06, 2006 8:51 am ]
Thanks Mick, I may not have been clear in my earlier post, he did say that the best option is what you just said, to weld just the speaker hole and attatch seatbelt mounts to that. He has done quite a bit of work on all cars, so i do trust him. He may not have been exactly right about the crumple zone so I understand where willy is coming from, but there is a nice way to say those things, Sorry willy about what I said. :D
Steve.
