It is currently Fri Aug 08, 2025 6:44 pm
 Post subject: Hub removal
PostPosted: Fri Jul 07, 2006 2:03 pm
Howdy, I'm having a bit of trouble with changing over my front wheel bearings. I have managed to remove the drive flange so far and the outer bearings came out with that, but I need to get to the inner bearings. To do this I've been told that I need to take off the hub. Do I need to take the pressure off the hydrolastic suspension to do this? Or can I just push the arms off the hub. Plus I need to release the ball joints to move the top and bottom arms, do I need one of those ball joint splitters or are there any other methods?
Any help will be much appreciated. Cheers
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Fri Jul 07, 2006 2:26 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
get a tie rod splitter to do the ball joints then once you have removed the hub get a drift to knock the races out then use the old races to put the new ones in this is the only way to do it
makka
PostPosted: Fri Jul 07, 2006 2:33 pm
Thanks for that makka.
PostPosted: Sat Jul 08, 2006 12:11 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries
makka
Users browsing this forum: No registered users and 112 guests
