It is currently Tue Aug 12, 2025 11:08 pm
 Post subject: sump guard fitment?
PostPosted: Sun Aug 06, 2006 3:09 pm
Hey
just went to fit a sump guard that i brought but there are no holes to bolt it on...is this normal?? do you have to drill holes in the subframe to fit them and is this safe??
Cheers James
'75 windowless van
~LOLA~
PostPosted: Sun Aug 06, 2006 3:27 pm
There were only holes drilled on mokes that were fitted with them , just line everything up and drill the smallest hole you need , just make sure it's lined up properly , I've seen some oval holes on subframes so the sump guard would fit and look straight ...
PostPosted: Sun Aug 06, 2006 4:10 pm
cheers mate
'75 windowless van
~LOLA~
Users browsing this forum: No registered users and 264 guests
