Last Check https://www.ausmini.com/forums/viewtopic.php?f=2&t=2114 |
Author: | minimarc [ Thu Sep 30, 2004 4:28 pm ] |
Post subject: | Last Check |
Picked up my brake master cylinder back from full rebuild so i just want to go through this bleeding thing Connect the master cylinder back up to pipes and pedal Fill with Brake Fluid Jack up the righ hand side of the car and attach plastic pipe to the bleed screws on the back and front wheels RH first unscrew the bleed screw put the other end of the tube into a glass jar with brake fluid in get friend to push the pedal full strokes untill no more air bubbles can be seen keep fluid full half way push pedal all the way to the floor then do up screws then next side Right or wrong Its a dual circuit brake master cylinder |
Author: | doogie [ Thu Sep 30, 2004 5:03 pm ] |
Put the car back together take it too your local brake specialist, get them to bleed it, the best $20-$30 you will ever spend, no aggression, no lying on the floor, no spilled brake fluid. Doogie |
Author: | minimarc [ Thu Sep 30, 2004 7:00 pm ] |
after what i ended up paying for the rebuild ![]() soo if i can do it i want to give it a go kinda a thing i wouldnt mind learning you know BUT if i fail i will take it to one |
Author: | 68matic [ Thu Sep 30, 2004 7:28 pm ] |
i find the best way is: no need to jack car up do all nipples up fill reservoir with fluid get someone to continually pump the pedal, about once every second you get under car open one nipple slightly watch it spurt out and get the timing close at half the spurt turn wheels max to get to front nipples do up with little spanner very messy put rag under and dont wear long sleaves/watch remember to adjust the brakes after, non adjusted brakes wont eat and you'll blame the nipple bleeding |
Author: | minimarc [ Thu Sep 30, 2004 7:42 pm ] |
wont need to adjust them they are newly adjusted so the way i described will/wont work |
Author: | 68matic [ Thu Sep 30, 2004 7:44 pm ] |
it looks like your way will be definitely much cleaner than the one ive described you can even do that yourself as well i say it will work. |
Author: | minimarc [ Thu Sep 30, 2004 7:55 pm ] |
thanks i hope so well i quess i will know by tommrow lolt it says in the haynes manual that for a dual circuit to do front and rear rh side first so two together then the other two hope this is righht |
Author: | 9YaTaH [ Thu Sep 30, 2004 8:48 pm ] |
Post subject: | Austin Powered!! |
68matic wrote: i find the best way is: you get under car
I just knew Mini Mi would have to be a Mini owner!!! ![]() ![]() ![]() |
