It is currently Sun Aug 03, 2025 4:56 am
PostPosted: Fri Aug 04, 2006 9:18 am
i was wondering.
now, the four is gonna be the kind of four that is on there allready but bigger, it is just i have lost that kind of font (damit damit damit damit)
this four though
door use to look like this
at the moment like this
doing a cheap and nasty job, :oops: but atleast it is an improvement.
i sanded of the loose rust, used rust converter on the rest, filled in all the holes, then sanded them down, then i filled in more holes and sanded them down then finally i filled in more holes and sanded them down, now i am applying layers of paint from a can, fun fun fun. so the "4" is deffinately there and so is "molly" down the boottom is gonna say the thing which is written on the sticker on the rocker cover. the bit below the top hinge says "lucas (in lucas font) [underneath] wiring and electronic gizmos"
there will be space for two other things when i improve molly more, basically cheapo brand name style like you see on rice burners.
(*not everything is to exact scale)
PostPosted: Fri Aug 04, 2006 9:38 am
Thats looks pretty sweet...
the only problem i can see is getting the stuff written in smaller fonts look neat.
will you be using custom decals for all the writing? or will you be spraying it on with a stencil?
1975 Hairy Lime/White Clubby
PostPosted: Fri Aug 04, 2006 10:10 am
stencil, but i had a feeling i would glue the stncil on with cheap glue, then just hose it off when i am done.
PostPosted: Fri Aug 04, 2006 10:43 am
i like the door the way it is 8)
get some decals made up :idea:
PostPosted: Fri Aug 04, 2006 11:01 am
Decals would look a lot better than cutting a stencil and painting them , not to mention being so much quicker , have you cut stencils out for something like that before , it takes forever ...
PostPosted: Fri Aug 04, 2006 3:21 pm
after much consideration i will look into it, but can anyone give me a ball park figure as to how much decals would cost? and would i have to buy bulk? cause then it is kinda bad.
PostPosted: Fri Aug 04, 2006 4:07 pm
never mind the decals, get the paint matched properly to the rest of the car :lol:
PostPosted: Fri Aug 04, 2006 4:34 pm
whinja ninja
whinja ninja
unsure on cost, but most sticker places will happily give you a quote. Go see a few.
I don't know my name anymore.
PostPosted: Wed Aug 09, 2006 1:00 am
Andrew i may be able to ask a mate in sydney who will do it cheap for ya, unless you want to fly over and pick them up off me, you know where i live!Also mate your miniworld cover is in this months magazine, noooiiice one matey
PostPosted: Wed Aug 09, 2006 9:03 am
andbat wrote:
Do a spell check first ;)
-Cam 8)
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
