It is currently Sat Jul 19, 2025 8:01 pm
 Post subject: Removing Fuel Tank
PostPosted: Thu Sep 30, 2004 9:23 pm
Having lent my Haynes manual to a mate, i am here wondering how to take the petrol tank out of the way to get to the back of the tail light (LHS duh) so i can put my new clear jobbies in.
If someone can give me a rundown of the Dummies guide that would be great.
PostPosted: Thu Sep 30, 2004 9:35 pm
1. OPEN BOOT
2. REMOVE BATTERY!!
High heel ninja
Take of the fuel cap, drain the tank, loosen of the strap, lift the tank out, reverse the procedure to re fit it.
Doogie
Do you need to change the whole unit or can you just change the lens?
Anyhow, here is how I would do it.
1. Remove petrol cap and drain petrol tank by siphoning through filler nozzle into suitable container.
2. When empty as much as possible, use a tube spanner to undo the drain cock from underneath the tank (under the car). Remember to use a spill tray or bucket. I would'nt recommend re-using this portion.
3. Open the boot and undo the nut on the retaining strap.
4. Disconnect the outlet hose.
5. Remove the tank through the boot opening.
PostPosted: Thu Sep 30, 2004 9:46 pm
Whole thing needs to come out. Rover lenses/lights are bigger ;)
PostPosted: Thu Sep 30, 2004 9:56 pm
Be sure to drain the tank completly!!!!! You have to take the hose off the bottom of the tank if you are removing it from your vehicle.
Don't do what I did and fill your boot with fuel, then have it leak through the numerous rust holes in the boot floor and kill the weeds on the paving below..... :lol:
Loosen the tank, lift and move it toward the middle of the boot area, then take the hose off.
I did just this at thw wreckers a few days ago.
On the subject of fuel tanks....anyone ever seen a Mini fuel tank that isn't rusted?!?!?!?
You don't need to pull the tank out- just move it sideways enough that you can get your fingies in to pull the wires off & undo the nuts. :wink:
PostPosted: Thu Sep 30, 2004 10:02 pm
Nar i might need to get it out.
I am putting in plugs so i can change back to the old tail lights easily if need be.
Where in gods name is the drain cock?
PostPosted: Thu Sep 30, 2004 10:05 pm
It's really a bit of pipe with hex on it- comes out near rear of tank towards middle of boot.
PostPosted: Thu Sep 30, 2004 10:34 pm
Ok so theres a hole in the boot floor, then this nut is on the bottom?
Do you have a pic?
As for the strap, theres a bolt i can see and two (i think) wires are earthed onto this bolt. Does the strap just go over the tank and at the back or what?
Im puzzled... and i havent even started! :shock:
PostPosted: Thu Sep 30, 2004 11:06 pm
on my tank it is a grub screw, not a hex head bolt.
PostPosted: Thu Sep 30, 2004 11:08 pm
Does it stick out under the car? IE through a hole in teh boot floor?
PostPosted: Thu Sep 30, 2004 11:12 pm
Nope. You would have to poke an allen key up into the tank, through the boot floor to undo it and drain.
PostPosted: Thu Sep 30, 2004 11:29 pm
Ok so i'll jack up the bum and look under where the tank is and I should see a screw?
PostPosted: Fri Oct 01, 2004 6:59 am
Open the boot and peer under the side of the tank, towards spare wheel. You should be able to see a hole in boot floor, between hold down strap and spare wheel well.
BTW unless you are taking tank right out, just undo the strap 1/2 way up where the clamp bolt is.
Anton, early cars had the tubehex thingy, going thru the floor. If you just have a plug it there you can probably remove tank with plug still in. :wink:
