Removing Fuel Tank https://www.ausmini.com/forums/viewtopic.php?f=2&t=2122 |
Page 1 of 2 |
Author: | willy [ Thu Sep 30, 2004 9:23 pm ] |
Post subject: | Removing Fuel Tank |
Having lent my Haynes manual to a mate, i am here wondering how to take the petrol tank out of the way to get to the back of the tail light (LHS duh) so i can put my new clear jobbies in. If someone can give me a rundown of the Dummies guide that would be great. |
Author: | 9YaTaH [ Thu Sep 30, 2004 9:35 pm ] |
Post subject: | Removing Fuel Tank - STEPs 1 and 2 |
wgormly wrote: Having lent my Haynes manual to a mate, i am here wondering how to take the petrol tank out of the way to get to the back of the tail light (LHS duh) so i can put my new clear jobbies in.
If someone can give me a rundown of the Dummies guide that would be great. 1. OPEN BOOT 2. REMOVE BATTERY!! |
Author: | doogie [ Thu Sep 30, 2004 9:35 pm ] |
Take of the fuel cap, drain the tank, loosen of the strap, lift the tank out, reverse the procedure to re fit it. Doogie |
Author: | 1310/71 [ Thu Sep 30, 2004 9:35 pm ] |
Do you need to change the whole unit or can you just change the lens? Anyhow, here is how I would do it. 1. Remove petrol cap and drain petrol tank by siphoning through filler nozzle into suitable container. 2. When empty as much as possible, use a tube spanner to undo the drain cock from underneath the tank (under the car). Remember to use a spill tray or bucket. I would'nt recommend re-using this portion. 3. Open the boot and undo the nut on the retaining strap. 4. Disconnect the outlet hose. 5. Remove the tank through the boot opening. |
Author: | poeee [ Thu Sep 30, 2004 9:46 pm ] |
1310/71 wrote: Do you need to change the whole unit or can you just change the lens?
Whole thing needs to come out. Rover lenses/lights are bigger ![]() |
Author: | J_A_M [ Thu Sep 30, 2004 9:56 pm ] |
Be sure to drain the tank completly!!!!! You have to take the hose off the bottom of the tank if you are removing it from your vehicle. Don't do what I did and fill your boot with fuel, then have it leak through the numerous rust holes in the boot floor and kill the weeds on the paving below..... ![]() Loosen the tank, lift and move it toward the middle of the boot area, then take the hose off. I did just this at thw wreckers a few days ago. On the subject of fuel tanks....anyone ever seen a Mini fuel tank that isn't rusted?!?!?!? |
Author: | drmini in aust [ Thu Sep 30, 2004 9:56 pm ] |
You don't need to pull the tank out- just move it sideways enough that you can get your fingies in to pull the wires off & undo the nuts. ![]() |
Author: | willy [ Thu Sep 30, 2004 10:02 pm ] |
Nar i might need to get it out. I am putting in plugs so i can change back to the old tail lights easily if need be. Where in gods name is the drain cock? |
Author: | drmini in aust [ Thu Sep 30, 2004 10:05 pm ] |
It's really a bit of pipe with hex on it- comes out near rear of tank towards middle of boot. |
Author: | willy [ Thu Sep 30, 2004 10:34 pm ] |
Ok so theres a hole in the boot floor, then this nut is on the bottom? Do you have a pic? As for the strap, theres a bolt i can see and two (i think) wires are earthed onto this bolt. Does the strap just go over the tank and at the back or what? Im puzzled... and i havent even started! ![]() |
Author: | J_A_M [ Thu Sep 30, 2004 11:06 pm ] |
on my tank it is a grub screw, not a hex head bolt. |
Author: | willy [ Thu Sep 30, 2004 11:08 pm ] |
Does it stick out under the car? IE through a hole in teh boot floor? |
Author: | J_A_M [ Thu Sep 30, 2004 11:12 pm ] |
Nope. You would have to poke an allen key up into the tank, through the boot floor to undo it and drain. |
Author: | willy [ Thu Sep 30, 2004 11:29 pm ] |
Ok so i'll jack up the bum and look under where the tank is and I should see a screw? |
Author: | drmini in aust [ Fri Oct 01, 2004 6:59 am ] |
Open the boot and peer under the side of the tank, towards spare wheel. You should be able to see a hole in boot floor, between hold down strap and spare wheel well. BTW unless you are taking tank right out, just undo the strap 1/2 way up where the clamp bolt is. Anton, early cars had the tubehex thingy, going thru the floor. If you just have a plug it there you can probably remove tank with plug still in. ![]() |
