It is currently Tue Aug 12, 2025 4:45 am
 Post subject: WA rego laws
PostPosted: Wed Aug 09, 2006 12:49 am
This post is aimed at WA based users, or people who have lived over here.
I moved over to Perth this year with my mini which is currently registered in SA. To register in SA all I did was a transfer over from the previous owner, and the car was nowhere near roadworthy :D .
Are the rules really tight in WA regarding roadworthyness (if thats a word). Main things I'm concerned about when I transfer over are:
1275cc engine with front drums
bit of dodge bodywork.
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Wed Aug 09, 2006 12:58 am
To register it over here you have to take it over the pits.
Is the current engine listed on your SA rego papers? Then the drum brakes with a 1275 should not be a worry unless your inspector happens to be a mini nut! Rust is a bit iffy - "structural rust" is a definate fail (subframes, mounting bolts, holes in floor pans).
Maybe Mick has his checklist from his failed inspection on Friday? :P
PostPosted: Wed Aug 09, 2006 1:25 am
Yeah the engine number is listed on the papers, good ol' SA system is full of loop holes. There is no structural rust or holes in the floor pans, plus I just reconditioned both hubs. Is there anything else I need to worry about? All the obvious things like lights and seat belts are all ok. Would be good to get it all official and not have to worry about coppers asking questions about my SA plates. The current excuse is "I'm on a holiday in sunny Perth".
PostPosted: Wed Aug 09, 2006 8:06 am
Maybe Mick has his checklist from his failed inspection on Friday? Razz
grumble, grumble, (bitches and moans to self quietly)
PostPosted: Wed Aug 09, 2006 12:52 pm
I would have thought you would have to swap to WA plates anyway. When I brought my car over, I had the owner deregister it in Queensland and then I just went through the usual process of pretty much getting a new vehicle on the road.
As long as your engine numbers match up, rust is either not present or not visible :lol: and you have no major things wrong then you should be fine. Oil leaks were a big one.
Torque Steer is a very evil thing. Fun..... but evil.
West Aussie Mini Boys Represent...!!!
PostPosted: Wed Aug 09, 2006 1:35 pm
Clean the engine bay & under the car, then do it again!
Make sure it's spotless.
The other major one is brakes:
- must pull up square
- cannot take off with handbrake on
and make sure you windscreen washer works, eh Mick :lol:
PostPosted: Wed Aug 09, 2006 1:52 pm
" It's a manual pump, not electric - it works you just have to press it a coupla times !! " (grumble grumble grumble rant)
All good now, rego'd and all.
PostPosted: Wed Aug 09, 2006 6:21 pm
Oh yeah, wipers, need to get that done at some stage. I delebrately avoided getting the car swapped over to WA license because I knew it wouldn't pass, and I didn't want to waste a whole year of SA rego.
Users browsing this forum: No registered users and 173 guests
