[quote="Dixon Bainbridge"]The helper springs seem ok. The back end is really bouncy around corners. Cono did tell me to take off the shockers from the front (they were fitted by a previous owner as a mod). He said something about them maybe throwing the back left side down to much around the corners.
I took them off, but all that seemed to happen is the steering got lighter and the front sat up when i accelerated.[/quote]
Only guessing, but maybe the PO fitted the shockers to control a wayward displacer in the rear.
I can't see the swing arm bushings causing the symptoms you describe, unless they are totally shot.......if the bushes were shot there would be some banging and carrying on back there....but that dosen't account for the wheel excursion.
I really think it is something to do with left rear displacer return valving (maybe
)......happy to be proven wrong...hope you get to the bottom of this (no pun intended)
