Ballast Resistors https://www.ausmini.com/forums/viewtopic.php?f=2&t=21325 |
Author: | Mick [ Thu Aug 10, 2006 2:54 pm ] |
Post subject: | Ballast Resistors |
I've gotta Triumph Stag/ jaguar E Type/ former Cooper S enthusiest here who on espying the Pulsar Dizzy upgrade in my mini is a little incredulous to see that a GT40R can be used without a ballast resistor for the whole time the engine is running. I've had a search through the previous posts and hven't found anything that would answer his questions. Did the Pulsars use ballast resistors at all, and what are the down sides for using a 1.5 ohm "R" coil that would make a ballast resistor a requirement in some installations? Also what does the conversion do to the current draw of a standard ignition system? obviously as it is 1/2 the resistance, it must draw about twice the current, has anyone had to install a relay in the ignition system yet? cheers Mick |
Author: | drmini in aust [ Thu Aug 10, 2006 5:05 pm ] |
Pulsar N12 with Hitachi electronic dizzys used a Jap 1.5 ohm coil standard, with NO ballast resistor. It just happens to be the same resistance as a GT40R. Some other electronic ign systems use a 1.1 ohm or even less. No big deal. Ballast resistors are used in POINTS ignitions, not electronic. ![]() <edit> the current draw is probably greater, but for how long is the question. They don't seem to get hot, as they do in a points system with no ballast resistor. |
Author: | Mick [ Thu Aug 10, 2006 6:16 pm ] |
Thanks Doc, I suspected as much. I'll pass on your wisdom. cheers |
Author: | ausminis4u [ Thu Aug 10, 2006 7:38 pm ] |
yeah the honda dizzys i built, i ran gt40r coils with them without a resistor. edit heres some pics for inspiration ![]() ![]() |
