68matic wrote:
1. aaron what were you doing drilling a hole in a radiator
2. i heard pepper in the radiator fluid will trail slowly to the leaking hole and plug it up
by the sounds of your hole, maybe whole peppercorns?
3. brazing job would be no more than $30, panel beaters should do it, make sure you clean it of the paint and get them not to heat the radiator surround material too much or it will melt and fall through coz its made of brass/copper, not steel.
steel has a higher melting point so you can heat it till red hot before feeding brass rods in
I'm a qualified welder.. but I've got no gas at the moment..
If it's in the top or bottom tank, I'd silver solder it. Trying to braze brass will burn holes & make a bloody mess of it. Silver solder is the best bet for sheet brass.
Take to a radiator specialist is the best option.
If the hole's in the core, bin it and find another rad.....!
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
