Webber advice..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=21371
Page 1 of 2
Author:  K-Bar [ Fri Aug 11, 2006 5:44 pm ]
Post subject:  Webber advice..
Gday everyone!
Ive recently had my 998 rebuilt up into an 1100.
Heres a couple specs,
ENGINE:
40 thou over bore
1100 crank
balanced
lightened fly
compression up to about 9.5, maybe more
sports cam, one up from a cooper S standard..( is a daily driver)
LCB extractors
1.75 inch exaust, RC 40 exit
HEAD:
Ported and polished
chamber shapes changed
bigger exaust valves.
Runs great..pretty fast...but im only using a 1.5 SU
my mini mechanic has offered a 45mm webber to me for $450...is on a swan neck manifold, and will be cleaned up to fit..
my QUESTION: Will it still be possible to choke it down enough to run nicely on my 1100.
i do know its more common to use a 40mm..just that i think this is a decent price for this 45.
any help please....thanks
K-Bar
Author:  h0nk [ Fri Aug 11, 2006 5:53 pm ]
Unless that price includes proper jetting and tuning for your engine I don't reckon it's a good price at all.. You'll have to put a weber box in aswell with the swan neck type manifold I believe? Otherwise you want to switch to a redline manifold which will cost you another $200
To answer your question yeh it's possible, chong (68deluxe) is running a 45 dellorto on this 1100cc engine.
Author:  Mini Mad [ Fri Aug 11, 2006 5:56 pm ]
Chong is running a 45mm OK on his engine, but i think a 40 would be better..
The swan neck is one of those crappy bent manifold alex, no need for a box and more room than the 3005 redline...
As alex said, if it includes the right chokes, jets and tuning, then it's OK ....
Author:  h0nk [ Fri Aug 11, 2006 5:57 pm ]
Oh hold up nah you won't need the box with the swan neck manifold will you.. but these are apparently inefficient compared to other manifolds..
To be honest I would stay with the reliable 1.5" su.. if it's working keep it!
EDIT: ah you beat me to it josh :)
Author:  speedy [ Fri Aug 11, 2006 6:03 pm ]
or instead of a 1.5", get a 1.75" SU. 8)
Author:  K-Bar [ Fri Aug 11, 2006 6:14 pm ]
yes price includes getting it set up..
ive looked around here and people dont sell webbers for that much.
the 1.5 is working, but i think it has issues..ive tuned it..done the spring and needle..but its using too much dashpot oil...and my mini is doing 9.4 litres per 100 Ks....thats not too good.
i thought a webber would be worth the shot
Author:  h0nk [ Fri Aug 11, 2006 6:17 pm ]
just don't go the weber for fuel economy :)
Author:  K-Bar [ Fri Aug 11, 2006 6:22 pm ]
yeh wat im saying is, if the SU is stuffed, and doing that, then i may as well go a webber with that lil bit extra feel to it
Author:  Mini Mad [ Fri Aug 11, 2006 6:32 pm ]
I have a similar amount of work done to yours (very similar spec actually) cept i'm running a 40mm dellorto and i get 9.8L/100km ...so i would expect that...this is a 40yo engine and you have added alot more power to it by modifying it, more power requires more fuel.
And i hate to tell you, but it ain't going to get any better with a webber! :lol:
Author:  K-Bar [ Fri Aug 11, 2006 6:48 pm ]
i KNOW that its an older engine..i KNOW that its hotted and will use more fuel...
im saying that im using a ONE POINT FIVE INCH SU..
i COULD have more fun on the same fuel...it flutters between 9.4 to 9.8 usage per 100kms... i COULD just use a webber
Author:  Mini Mad [ Fri Aug 11, 2006 6:59 pm ]
I do understand numbers and decimal points :lol: i didn't think you were running a FIFTEEN INCH SU...
There's no need to yell, we were all trying to help YOU
Maybe someone who doesn't KNOW will read this and learn something.
Author:  K-Bar [ Fri Aug 11, 2006 7:18 pm ]
Author:  Spaceboy [ Fri Aug 11, 2006 7:27 pm ]
i would fit twin hs2's or a single hif44, i reckon the weber is overkill, and i think you'll dump a lot of petrol down the exhaust pipe
Author:  h0nk [ Fri Aug 11, 2006 7:29 pm ]
Well overall:
It IS possible to get the 45 jetted for your engine.If the $450 includes manifold, linkages, and completely set up for your engine then I'd say it's probably worth it. But just remember if theres bits missing it all adds up:
linkage kit ~$90
air filter assembly ~$60
soft mount kit ~$40 - $50
jets can cost a fortune aswell!
Author:  drmini in aust [ Fri Aug 11, 2006 7:38 pm ]
Jets and emulsion tubes for a 45 Dellorto cost around $100, Weber prices would be similar.
Chokes are extra if the ones in it are too big. :wink:
