What do you think of this subframe. https://www.ausmini.com/forums/viewtopic.php?f=2&t=21374 |
Author: | clubmn [ Fri Aug 11, 2006 7:08 pm ] |
Post subject: | What do you think of this subframe. |
http://cgi.ebay.co.uk/MINI-RACE-RALLY-B ... dZViewItem Be a little lighter, seems 2 be a good way to go?, what would Aus Regs say about this? |
Author: | sports850 [ Fri Aug 11, 2006 7:13 pm ] |
A lot of people in the UK have used them with very good results , a bit lighter , but a lot more adjustable and less likely to trap the salted slush from the roads .... |
Author: | feralsprint [ Fri Aug 11, 2006 7:32 pm ] |
Thats pretty much the same as the Midas rear suspension except it uses the original trailing arms ![]() ![]() Jon |
Author: | h0nk [ Fri Aug 11, 2006 7:46 pm ] |
Doesn't vizard endorse these in his books? well a similar setup anyway |
Author: | Mokesta [ Fri Aug 11, 2006 8:43 pm ] |
The name is misleading. It's note really a beam axle, just trailing arm with coil overs. Not bad, nice and light and same suspension geometry as standard mini. |
