It is currently Wed Aug 20, 2025 11:41 pm
 Post subject: Gearboxes
PostPosted: Wed Aug 16, 2006 9:27 pm
Is there any difference between a small block box and a large block box
PostPosted: Wed Aug 16, 2006 9:28 pm
theres a few different types, rod change, remote change, pudding stirrer
i am pretty sure that any engine can bolt on to any type of gearbox
cooper and cooper S and GT has different gear ratios
there are different diff ratios too :lol:
PostPosted: Wed Aug 16, 2006 11:05 pm
:lol:
Not quite right. But you're close.. :wink:
If talking 4 synchro boxes- whether remote or rodchange, any engine including 1275S or Morris 1100S will bolt on and the crank & rods miss everything.
These days, most people are using these boxes, so no problem.
But, with 3 synchro ones it's not quite that simple- the old 850 boxes foul the 1275's conrods big time- not worth trying. Some of the other cases need a bit of grinding here and there for things to miss.. :wink:
PostPosted: Wed Aug 16, 2006 11:11 pm
thanks doc, try to remember that
