the wonders of mini locks!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=21621
Author:  thomen [ Fri Aug 18, 2006 9:09 am ]
Post subject:  the wonders of mini locks!
hi all alas my drivers door lock has fallen out of the hole aka it turns in the hole in the door when i turn my key... does anyone know what the best adhesive is to use to stick the lock back to the door?
a friend suggested sicaflex (spelling?) but i was wondering if there was a general concensus?
Author:  buztoy [ Fri Aug 18, 2006 10:19 am ]
just replaced my locks with those solex locks, a bit of filing and stuff but they work great, the way the original lock is held in is a little clip, scrounge in the bottom of your door, it wraps around the lock and has 2 wings poking out either side, dont glue it your lock need the clip to hold it still, when you turn that lock about the 2nd time it will turn it will just snap loose,
failing finding the clip, nock something up with a washer so at least you can give that glue some surface area to grab,
Author:  thomen [ Fri Aug 18, 2006 10:24 am ]
thanks buztoy!
i shall try and have a play this weekend and see if i can fix it up!
do the solex locks fit in the original holes?
much more secure?
Author:  Mini Mad [ Fri Aug 18, 2006 10:25 am ]
solex locks are ugly though :( not for penny lane... ;)
Author:  thomen [ Fri Aug 18, 2006 10:29 am ]
hehe ok well if i can get my current lock to stay in the door all will be happy!
Author:  buztoy [ Fri Aug 18, 2006 10:43 am ]
they need a bit of cutting, i did it all with a hack saw blade no hack saw, they look a bit out of place
Author:  thomen [ Thu Sep 28, 2006 11:33 pm ]
anyone know why my drivers door lock would fall out?
is there a washer that needs to go on the inside skin?
Author:  gzeVan [ Fri Sep 29, 2006 2:27 pm ]
most auto door locks have a rubber seal between the panel and the barrell you could try an O ring ,it will give it a tight fit but wont stop it from being forced buy a screwdriver
if you have a clubby with the long key try using a 90,s laser door lock, you will find that the mini ignition key will fit inside this , get a locksmith to rekey it and fit that, I have now done three mini's and is the best option
PM if you need any help Im a locksmith in Penrith
Author:  thomen [ Fri Sep 29, 2006 2:33 pm ]
awesome thank you!
i have the rubber under barrel things.. but haven't fitted them yet...
it's popping out quite alot i thought maybe there were some form of metal prongs or a washer of some type that would hold the barrel to the internal door skin...
but oh well!
Author:  Spaceboy [ Fri Sep 29, 2006 2:58 pm ]
i'd love some more info/pics about this mod :D
Author:  gzeVan [ Fri Sep 29, 2006 5:10 pm ]
no worries i will take some pics and start a thread on it
