rover mini on ebay https://www.ausmini.com/forums/viewtopic.php?f=2&t=2166 |
Page 1 of 2 |
Author: | madarsemini [ Mon Oct 04, 2004 7:44 am ] |
Post subject: | rover mini on ebay |
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 11219&rd=1 Hi guys and girls. There's a rover mini on ebay at the moment starting price is $500. One of the questions is Do you have an import approval for this vehicle. Essentially to import with a view to register you need to clear this with Australian vehicle standards before the car reaches Aus. If you don't have one this is a parts car only....unless you know of some other way around it? The answer to this was A: According to the company I spoke to in regards to registering the car, it shouldn't be a problem as there are other Rover minis in Australia, and they have dealt with them in the past. My question to all. Can this car be registered in Australia if it doesn't have import approvel papers? Because who ever buys it may end up having to use the car as a parts only vehicle. Cheers madarsemini |
Author: | drmini in aust [ Mon Oct 04, 2004 7:50 am ] |
The other Q that took my eye is: Q: Can you please tell me what needs to be done/costs to get this car licensed. Regards answered on: 03-Oct-04 A: The only thing that I know that needs to be done to get the car registered is having a limiter put on it so that you can't start it in gear. Not that simple- it would already have an interlock to stop being started in gear, real problem is these early ones (like our old MiniMatics) had no `Park' position which is now required by ADRs. Later UK autoboxes did have the P but these don't.....! |
Author: | tzi [ Mon Oct 04, 2004 12:46 pm ] |
.... with regards to rovers? I see what looks like a moris A series in there... but whats all the other crap? if its not fuel injection... then whats the benefit? |
Author: | marconi [ Mon Oct 04, 2004 1:07 pm ] |
Air conditioning. Ahhhhhhhh summer is nearly here. ![]() |
Author: | bnicho [ Mon Oct 04, 2004 1:58 pm ] |
It's interesting that the seller doesn't mention it has Air Con. Maybe he does not realise. ![]() Same type of A/C as I have stored away to put in my Traveller BTW Doc, all Mini Autos have an interlock to prevent starting in gear. On the pre-Park boxes you must be Neutral for the starter to turn. No problem with that part - should be easy to get working. No import approval is more of a problem! If the seller does not have the paperwork there is no way anyone can legally register this car in Oz. |
Author: | drmini in aust [ Mon Oct 04, 2004 2:28 pm ] |
bnicho wrote: BTW Doc, all Mini Autos have an interlock to prevent starting in gear. On the pre-Park boxes you must be Neutral for the starter to turn. No problem with that part - should be easy to get working.
I realize that, as I stated (I've owned 4 AP autos, lol) but current Oz ADRs require a `Park' position. This one doesn't have it, not sure if it's build date is before the cutoff date for this requirement, or not. ![]() |
Author: | ryan23 [ Mon Oct 04, 2004 4:37 pm ] |
bnicho wrote: No import approval is more of a problem! If the seller does not have the paperwork there is no way anyone can legally register this car in Oz.
yeah dont make the same mistake as i did - i did not thoroughly gone thru the paperworks b4 buying the car! then realise i hadnt had all the paperworks!!! had to go thru the trouble of tracking down the import company and have them re-write a form for me (took 4eva) - thank god at least the car i bought was LEGIT! |
Author: | madarsemini [ Mon Oct 04, 2004 5:50 pm ] |
The guy says he called some company where they said that registering it wasn't a problem because there were other rover mini's in australia. I think the guy doesn't realize that there are papers that are needed to confirm the car legal on our roads. |
Author: | ryan23 [ Mon Oct 04, 2004 6:35 pm ] |
madarsemini wrote: The guy says he called some company where they said that registering it wasn't a problem because there were other rover mini's in australia. I think the guy doesn't realize that there are papers that are needed to confirm the car legal on our roads.
ask when the car was offically imported? ages ago? then u'll need the cert from DOTs and the 0405 document (original not photocopy) |
Author: | Harley [ Mon Oct 04, 2004 6:59 pm ] |
It's possible that the car could be still used if there aren't papers. When I was at Northern mini parts last month I found it intriging that his latest car, a '95 rover was registered as a '72 model. Suppose you won the car and fitted another engine built in Aus. Could the car be used? |
Author: | madarsemini [ Mon Oct 04, 2004 7:25 pm ] |
the guy now has a buy it now price for it $4500. Bit pricey i think for what his telling us. Also can that actually work, i mean importing vehciles that are less than 15 years old and registering them as a 15 year old car or older? |
Author: | 68matic [ Mon Oct 04, 2004 8:07 pm ] |
of course it works, if youve got the write people at with right price ![]() |
Author: | Harley [ Mon Oct 04, 2004 8:19 pm ] |
New cars reg as old cars sounds dodgy to me, but there were 3 rovers down at NMP, all registered as pre- '75 models. The way it was put was if a a car (say a '74 clubby) had every component replaced except one, Is it still the original car? I'd say no, but it depends on body numbers and things like that. |
Author: | mutant mini [ Mon Oct 04, 2004 8:59 pm ] |
Don't think it is entirely legal. But depends if you are willing to take that chance. Someone in Qld. got caught selling some clubman body plates that were put on a late model then the guy stupidly tried to re register the clubman. Well they worked this one out. |
Author: | PhildoD [ Mon Oct 04, 2004 9:02 pm ] |
Trading and swapping of Body numbers and compliance plates, is BLATANTLY ILLEGAL. It's the sort of thing that chop shops use, and they will even rebuild two trashed cars into one. How many people here would like to know they are driving two halves of a car, that have been welded together in some backyard workshop?? |
