I have recently replaced the right side headlight bulb in the van as part of the drawn out process of getting the car ready for rego. After putting it all back together we tried it and it worked OK. It was only turned on for a short time.
Just before I took the van to the mechanic for the first look over I decided to check all of the lights to make sure they were still OK. After turning the lights on the low beam blew. Then when we put it on to high beam it blew as well.
Can someone give me any hints as to what may have caused this please. As I said the bulb was brand new so I'm not sure if it could be a wiring problem.
Thanks.
Ziff
