It is currently Sun Aug 24, 2025 5:09 pm
PostPosted: Fri Nov 11, 2011 9:50 am
Can you buy these separately from a whole cylinder as my passenger rear must have died this morning seeing my brakes sh#t themselves when I tried to slow down on the freeway and i saw some steam coming from the passenger rear. Lost a lot of pressure but managed to come to a stop
I drove the rest of the way nice and slow and will have to park it this weekend unless you can buy the seals from supercheap or autobarn or something
PostPosted: Fri Nov 11, 2011 9:57 am
Yes you can, Supercheap and co can get them but I doubt anywhere keeps them on the shelf.
Entire cylinders are pretty cheap so depending on the age of yours its pretty economical just to get whole new ones.
PostPosted: Fri Nov 11, 2011 10:13 am
Havent checked if mine are original or not but dont people say the new ones arent as good as the originals
PostPosted: Fri Nov 11, 2011 10:27 am
Any decent brake shop or a Mini place should have these seals in stock.
Most Supercrap stores these days don't know what a Mini is. :lol:
Measure the piston diameter, or take a piston with you as a sample.
Most cylinders fitted to Oz Minis are 3/4" diameter, except Cooper S or others with disc front brakes- these use 5/8" ones to prevent locking up during heavy braking.
PostPosted: Sat Nov 12, 2011 6:18 pm
Be sure to check the condition of the cylinder before you go fitting new seals. Look for any pitting, scoring, rough spots etc.
