It is currently Fri Jul 25, 2025 8:14 am
 Post subject: Jet drills
PostPosted: Thu Aug 24, 2006 9:37 am
Does anyone have any idea where I could source a set of metric carb jet drills from in Australia? I'm looking for a set of drills ranging from 160 to 200 in 0.05mm increments (ie 1.60mm, 1.65mm, 1.70mm. . .on up to 2.00mm).
Anyone have any ideas?
 Post subject: Jet Drills
PostPosted: Thu Aug 24, 2006 9:08 pm
Most large engineering supply mobs have them
SKF, the bearing people supply them in both number & letter size, they come
in two small plastic trays
I know because I bought some when I was running methanol in the bike
Blue
Keep shiny side up
 Post subject: Drills aint Drills??
PostPosted: Thu Aug 24, 2006 9:14 pm
excuse my ignorance fellas....but....is there anything special about these drill bits except for the custom sizes :?:....they would want to be accurately (symetrically) ground and sharpened so that you got the advertised size....
PostPosted: Thu Aug 24, 2006 9:25 pm
Nothing realy special about the drills, & with methanol you have a larger
tollerance, campared to petrol, between too lean & too rich
Blue
Keep shiny side up
 Post subject: Re: Jet drills
PostPosted: Thu Aug 24, 2006 10:11 pm
[quote="blumin"]Nothing realy special about the drills, & with methanol you have a larger
Blue[/quote]
Tanks...and the smell is to die for 8).....hows the 850 going :?: :)
PostPosted: Thu Aug 24, 2006 10:17 pm
I've never really liked drilling jets - when i was Drag racing the mixture was always inconsistent with drilled jets and not with store-bought ones...
(Holley carb)
FOund out later that there are chamfers and radii on the inlet and outlet of the jet that can be highly affected by changing the size of the orifice without modifying the chamfer to compensate...
That said, any engineering should should be able to sell you a set of Number drills ..... any number of variations in size then :-)
if that still isnt enough, there are techniques for re-sharpening the drills that will make them drill over, or even UNDERsize :wink:
Good Luck
J
PostPosted: Thu Aug 24, 2006 10:32 pm
[quote8).....hows the 850 going :?: :)[/quote]
Parked in the shed awaiting funds
Blue
Keep shiny side up
PostPosted: Fri Aug 25, 2006 10:47 am
Ah-hah!
http://www.hobbymechanics.com.au/xdrills.htm
Thanks for other suggestions. . .
Users browsing this forum: Barkfast and 86 guests
