It is currently Sat Jul 19, 2025 8:43 pm
 Post subject: 1275 question ... Plugs
PostPosted: Fri Aug 25, 2006 7:38 pm
Call me stupid but... What spark plugs do 1275's normally run? I have a set of NGK BP 5E S spark plugs .. these ok?
PostPosted: Fri Aug 25, 2006 7:43 pm
They normally ran BP6ES, but with unleaded fuel now, BP5ES are fine. :wink:
PostPosted: Fri Aug 25, 2006 8:36 pm
k. ... more on this... i have found my engine (though i don't like to admit with 2 x 5E and 2x 6E spark plugs "recently purchased engine" runnning. . should i check something out... compression test was 180- 190 on all cylinders. tested twice... advice welcome..
PostPosted: Fri Aug 25, 2006 9:59 pm
that pressure is fine.
I'd make all plugs the same, if mostly city use stay with the BP5ESs.
