It is currently Mon Jul 28, 2025 5:22 pm
PostPosted: Sun Aug 27, 2006 4:39 pm
Can a 1275 3 Gague Cluster (Spedo, Temp/Fuel and Tacho) work on a 1977 Clubman?
What would I have to do to make it work?
Thanks Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Sun Aug 27, 2006 4:50 pm
Bolt it in and add a wire to the tacho form the coil.
PostPosted: Sun Aug 27, 2006 4:57 pm
3 guage clusters came on smallbores also.
plugs straight in.
PostPosted: Sun Aug 27, 2006 5:00 pm
Sweet :D
PostPosted: Sun Aug 27, 2006 5:01 pm
Just a note, very early ones had a screw on speedo cable and later ones have a clip on cable.
PostPosted: Sun Aug 27, 2006 5:05 pm
Thanks for your help guys...
PostPosted: Sun Aug 27, 2006 5:07 pm
On all the clubbie harnesses I have seen the tacho wire is normally already there. From memory it's white. If there's no tacho, they join the two bullet connectors together. To install a tacho, simply unplug and plug into the relevant connectors on the tacho.
Matching the speedo cable s Morris 1100 says is the important thing to watch.
KB
PostPosted: Sun Aug 27, 2006 5:09 pm
Yeah it's clip on and I know what wire you are talking about :D
PostPosted: Sun Aug 27, 2006 5:10 pm
the 3 guage cluster has a larger bracket to hold it in place thats bolted to the firewall, you'll need to swap that also.
yeah theres two different speedo cable types, the earlier screw on type and the later clip on type... thank god they're the same on the engine end though.
PostPosted: Sun Aug 27, 2006 5:17 pm
I an getting bracket aswell :D Lets just see how easy it's to fit when it comes :D
PostPosted: Sun Aug 27, 2006 5:25 pm
you'll have no problem with it 8)
PostPosted: Sun Aug 27, 2006 5:34 pm
.... except like all the crummy Clubby tachos, it'll stick when started up... :lol:
Ah well, my Fiat 124S's fuel gauge was the same.... :wink:
Users browsing this forum: Bing [Bot] and 71 guests
