It is currently Thu Aug 07, 2025 11:22 pm
PostPosted: Mon Aug 28, 2006 7:10 am
hi do these emgines fit into minis and mokes also do the front disc brakes fit
thanks jamie
please i kneed help
PostPosted: Mon Aug 28, 2006 7:48 am
Morris Mini Minor engines are made for minis. I think your talking about the Morris Minor engine which i think doesn't fit in the mini.
DO IT ONCE, DO IT RIGHT
PostPosted: Mon Aug 28, 2006 8:09 am
Are you thinking of a morris 1100 (4 door sedan ) ? The engine is common to a mini with some modifications to the mounts (got to cut the wings off the front plate that has mounts for the 1100) but the discs don't fit , also I think the subframe is a bit wider and also won't fit .
PostPosted: Mon Aug 28, 2006 9:13 am
I am after front engine mount plate for an 1100 - I would gladly swap a mini front plate and mounts for one
PostPosted: Mon Aug 28, 2006 9:19 am
I once spent and entire week on kangaroo island..
sorry.. i thought i'd just add to the string of unrelated posts in this thread...
PostPosted: Mon Aug 28, 2006 10:00 am
the subframes are huuuuge, and it's best to change the diff housing as well, though they will go in with the 1100 remote change
PostPosted: Mon Aug 28, 2006 2:10 pm
Or if you are talking about a morris minor then the answer is no (not without work), 'cause they're north/south.
 Post subject: History....
PostPosted: Mon Aug 28, 2006 6:36 pm
[quote="smac"]Or if you are talking about a morris minor then the answer is no (not without work), 'cause they're north/south.[/quote]
But Sir Alec first experimented with East West in the Minor :wink:
