Fitting a Smiths Oil Pressure Gauge https://www.ausmini.com/forums/viewtopic.php?f=2&t=2192 |
Author: | 71_mini_k [ Tue Oct 05, 2004 1:19 pm ] |
Post subject: | Fitting a Smiths Oil Pressure Gauge |
Can anybody help ![]() I have a 71 Mini K with a standard 1100 engine. Since I have owned it the Smioths Oil Pressure gauge has not worked and so I wished to fix it. I checked the gauge and discovered that the feed pipe was missing, I have since obtained a pipe and can fit it to the gauge but do not know where on the block to fit it. I have read both my manuals and they didn't help much, they just say the back of the engine and I have looked but it is not that simple. Please Help! Thanks |
Author: | min13k [ Tue Oct 05, 2004 2:01 pm ] |
do you know where the oil pressure switch is ?? makka |
Author: | 71_mini_k [ Tue Oct 05, 2004 2:31 pm ] |
On the front of the motor (my left it's right) , above the starter motor and just above the distributor... ![]() |
Author: | min13k [ Tue Oct 05, 2004 4:11 pm ] |
OK is there a spot on there to hook the line up if not you need the lil thingamy to hook it up there as that is how it get the pressure um i'm rambling again sorry 5 beer for the day ![]() makka |
Author: | drmini in aust [ Tue Oct 05, 2004 5:08 pm ] |
Usually on a Mini-K, late `matic or Coopers the oil pipe goes straight into the block there, but if you have a switch for an oil light, you need a 1/8 BSP brass tee and a 1/8 BSP nipple, so you can fit both. ![]() |
