[quote="Mike_Byron"]Waaaaaaaaa !!!!!!!!!!!!!!!!!!!!!!!!
[b]Stop Stop Stop[/b]
You are trying to replace a CV boot - you do not need to to bash out a pot joint -[b]You do not need to bash out a pot joint.[/b]
Undo the large nut holding the CV into the disc - drum set up - same deal both systems different sized nut - thats all.
Now - jack the car up and safely place it on jack stands. Take off the front wheels and use a ball joint splitter to separate the top ball joint taper from the eye on the hub. Pull the whole assembly towards you and the inner CV (pot joint) cage, balls and boot will pull out and off the steel circular pot joint holder. There are six balls - they will fall out of the cage so watch for them.
Then continue to undo the outer nut holding the CV into the hub. When the nut is off, withdraw the entire axle/halfshaft assay to towards the gearbox and down. With the axles out - give the CV assay a couple of downward bashes with a FBH - if you are not game take it to a garage - theywill charge you peanuts - with the CV off , replace the boot and press the Cv back onto the axle. Its only held on by a expandable flex steel circlip type of washer.
Put the whole thing back together, slip it into the CV, bolt it up to the Disc or drum hub. Repack the inner CV (pot joint) with CV grease and carefully refit all six balls and slip the assay into the round pot joint holder as you refit the top ball joint. Do it carefully and it may take several goes but you must have all six balls in the round pot joint holder. seal the inner CV boot and tighten the alloy strip. Tighten the ball joint bolt until the taper is locked and move to the other side.
You do not need to bash out the inner pot joint holder - and if you do you are only going to dump the entire sump contents onto the what ever surface the car is jacked up on - be it lawn, concrete or the BBQ pavers.[/quote]
He said....Yeah, i had a little bit of trouble getting them out of the hub, mostly because in the end i only managed to crack the upper and lower ball joints and couldn't fit the puller or ball joint separator on the steering ball joint. I managed to get it out by turning the steering to the right point.
So the hub is hanging by the tie rod end....if you give the pot a descent whack it should seperate with all that movement .....obviously, tie rods seperated would be better.....and obviously if he had followed you method from the start we wouldn't be here
