It is currently Tue Aug 12, 2025 7:34 am
 Post subject: wont rev past 4000rpm
PostPosted: Mon Aug 28, 2006 4:09 pm
i have a a+1293 with a bit of work done and a 45mm weber i have changed the plugs and it has the standard dizzy in it it backfires and carrys on like a mad woman shitting at 4000rpm plus if anyone can help with any ideas it would be appreciative :cry:
PostPosted: Mon Aug 28, 2006 4:15 pm
nothing wrong that :!:
PostPosted: Mon Aug 28, 2006 4:18 pm
there is something wrong because im used to alot more than that :cry:
PostPosted: Mon Aug 28, 2006 5:05 pm
check points gap and change dizzy cap and leads.
1974 Moke - 998cc
PostPosted: Mon Aug 28, 2006 5:07 pm
sorry should have said it was a electronic dizzy
PostPosted: Mon Aug 28, 2006 5:24 pm
Have you checked you're ignition timing?
I'm assuming this has just 'happened' or have you made any changes right before it started? If so, what?
Matt
PostPosted: Mon Aug 28, 2006 5:34 pm
it went to the mechanics to get a few jobs done and came back like that
PostPosted: Mon Aug 28, 2006 5:53 pm
Is the fuel pump able to keep up supply to the Weber? Maybe its starving?
Hmmmm - mechanic trustworthy - I ask as I have had mine returned with nearly 80km over what I had on it when I dropped it off and had a sound thrashing at the hand of the so called "professional".
If trustworthy - sounds like they have mucked about with the advance or the jetting(guesstimation...lol)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Aug 28, 2006 5:54 pm
check fuel feed rate, should pump at lease one litre per minute, if it doesn`t then maybe blocked fuel filter, squashed/kinked fuel line, or pump could be sad
plenty more things to check like sticking carby piston, etc etc etc
do the fuel volume check first tho & then go from there
PostPosted: Mon Aug 28, 2006 6:19 pm
fuel pump is a facet pump mounted on the rear subframe they did have the engine out to fix oil leaks and second gear
PostPosted: Mon Aug 28, 2006 6:24 pm
I thought those noisy pumps only supplied like 2-3psi? I wouldnt of thought that would be capable of supplying a weber with enough fuel? My twin SU's needed a rotary vane style pump which puts out around 5psi i think. The noisy new facet pump couldnt keep up....
PostPosted: Mon Aug 28, 2006 6:40 pm
Fuel pressure and fuel volume are two different things.
You can have a 10psi pump that will not have the output volume to keep the carby full. But you can also have a 2.5psi pump that will empty the tank in minutes if a hose splits. :wink:
PostPosted: Mon Aug 28, 2006 7:21 pm
timing. Have you checked it?
PostPosted: Mon Aug 28, 2006 7:25 pm
start with the easiest thing first
take your plugs out and check them
check your timing.
Users browsing this forum: No registered users and 267 guests
