It is currently Fri Aug 01, 2025 1:53 am
 Post subject: Spark plugs.. again
PostPosted: Sat Jun 25, 2005 5:54 pm
I replaced my spark plugs not to long ago, and they need replacing again.. the old ones had carbon on them in the middle 2 cylindars only, the outer 2 were fine. I'm pretty sure it was carbon not oil. Does this mean I'm running too rich? Could I be leaving the choke out too long when I warm up the engine? Could it be anythign else?
Thanks
PostPosted: Sun Jun 26, 2005 8:20 pm
anyone?
(bump) :D
PostPosted: Sun Jun 26, 2005 8:31 pm
Choke or generally too rich is right. It sounds like you have a stocko manifold too. I would wind the carb back a flat and see how you go. drive it to work and back and see what the plugs are like. Wind it back 1 flat at a time, you really don't want to go too lean. If you have a std manifold, think about an update, or take it to a tuner and get them to sort it out. Costs money but best way to get your car running at it's peak. I just had my clubby tuned and you wouldn't think that the thing had the herbs he has now!
Aaron
PostPosted: Sun Jun 26, 2005 10:43 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
honk how is the compression across the 4 cylinders ??
makka
