Essential
https://www.ausmini.com/forums/viewtopic.php?f=2&t=2195
Page 1 of 3
Author:  willy [ Tue Oct 05, 2004 4:48 pm ]
Post subject:  Essential
Hey just wondering what are the essential road-side tools for a mini. Eg tools that would be used in an emergency.
Spanners - what size?
Screwdrivers?
Pliers?
anything you can think of, coz im making up a nice little tool pouch / box for my new boot 8)
Author:  drmini in aust [ Tue Oct 05, 2004 5:04 pm ]
I carry the following:
Mini side jack & wheelbrace,
4 way wheelbrace,
screwdrivers- a #2 Phillips & 3 flat ones,
cheap open ended spanner set- from 5/16 A/F- 5/8 A/F,
spark plug socket & bar,
spark plug set,
6" shifter,
pliers,
wire cutters,
multigrips,
razor blade,
penknife,
feeler gauge set,
torch & batteries,
6" of heater hose (for bypass),
top rad hose,
bottom rad hose,
split pin (front hub),
fan belts (2),
6 cable ties,
2 radiator bracket grommets...
Probably other bits I've forgotten...
I used to carry a spare dizzy (complete..) :shock: but now with the Pulsar dizzy I don't bother. :lol:
Author:  mutant mini [ Tue Oct 05, 2004 6:07 pm ]
And where might one carry all these various items :?:
Author:  willy [ Tue Oct 05, 2004 6:56 pm ]
Jan; in the boot :lol:
"5/16 A/F- 5/8 A/F" - what sizes does this contain? Also what is A/F?
Also, where should i get these tools? As i would want new (or even SH) stuff to use purely for the mini; i've got an extensive range at home.
Also, what spark plugs do you use/ what is recommended and do you carry a full set (4) ?
Author:  drmini in aust [ Tue Oct 05, 2004 7:22 pm ]
A/F means `across flats' ie width of spanner.
I think they are-
1/4-5/16,
3/8-7/16,
1/2-9/16,
5/8-3/4.
They fit 99% of what's on a Mini. Buy `chrome vanadium' spanners, they are stronger than Chinese `forged dogturd'.. Brand matters less- my roadie spanners are made in India.. :shock:
Where to buy? I just kept my eyes open- if they looked OK I bought them. Some came from Big-W, K-Mart, etc. They are only to get you out of trouble..
Yeah I do buy better ones for home/work- Sidchrome, Craftsman, Kinchrome, etc.
Spark plugs- if it's stock, I'd use NGK BP6ES or Bosch W7DC.
I use Bosch W6DC or NGK BP7ES in my 1310 (colder plugs- my motor is modded a fair bit)
Jan,
I have room for 2 plastic toolboxes and a plastic crate in the boot. And twin tanks..Sorry, no subwoofers, amps, etc and yeah it does look shitty... :lol:
Author:  thommo09 [ Tue Oct 05, 2004 8:10 pm ]
hey will, harris scarfe's has a sale on at the moment.....there's a few socket and spanner sets going pretty cheap
38pc stanley socket set for $50....not bad
Author:  willy [ Tue Oct 05, 2004 8:38 pm ]
Ah! I might go in there tomorrow.
Would they have ring or open spanners you rekcon?
Cos this is what the doc recommends 8)
Author:  drmini in aust [ Tue Oct 05, 2004 9:57 pm ]
Ring spanners or ring/ open or open end- "duz'n matter..." as Con would say.. :lol:
Author:  minimarc [ Tue Oct 05, 2004 10:13 pm ]
geeeez Doc you should slap an RACQ sticker on the side
youve got it all covered
Author:  drmini in aust [ Tue Oct 05, 2004 10:17 pm ]
Nah- I draw the line at carrying a torque wrench or socket set.. if it's that unreliable it can stay at home! :lol:
(but in my Fiat 124S, I carried a head gasket set, sockets, torque wrench.. clutch cable, throttle cable, oil pump drive gear, timing belt, yada yada....
I adhered strictly to Murphy's Law). :wink:
Author:  minimarc [ Tue Oct 05, 2004 10:22 pm ]
yeah well if i knew how to use it all id probably carry it too :oops: :oops:
but im learning its funny having two minis has doubled the speed at which im learning :lol:
actually looking under the bonnet of new cars if they do break down how the hell do you fix em its rediculus need to take even more tools plus a laptop
Author:  mutant mini [ Tue Oct 05, 2004 10:57 pm ]
Well I guess I'm the odd one out. Only have space for my four subwoofers, 35 litre petrol tank, 2 Mono Block amps, 1 x 4 channel amp, fuse box with neon, multiple LED's and my Odyssey battery.
:roll: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Author:  boost_morrre [ Tue Oct 05, 2004 11:06 pm ]
i think all of you are missing the no 1 tool in which mini's require the MOST and is essential in every MINI!!!!
*********WD-40!!!**********
Author:  willy [ Tue Oct 05, 2004 11:09 pm ]
Yeah! They made that small can especially for Minis 8)
Author:  drmini in aust [ Tue Oct 05, 2004 11:11 pm ]
Don't need it no more... I got Pulsar electronic dizzy, and moved the coil where it don't get wet!!
No more problems in wet weather.. 8)
Page 1 of 3 All times are UTC + 10 hours
