Just had a thought https://www.ausmini.com/forums/viewtopic.php?f=2&t=21985 |
Page 1 of 3 |
Author: | TheMiniMan [ Tue Aug 29, 2006 12:39 pm ] |
Post subject: | Just had a thought |
Well,,,the other day (last wednesday) i whipped up this little toy for motorkhanas/hillclimbs/autocross etc,,, Yamaha R1 engine, 140hp, 6 speed sequential gearbox with mini limited slip diff & the usual little basic minimal frame buggy type idea---> ![]() Then!!!!!!!!!.......I thought that it could use just a "little" bit more power---> ![]() so i chucked the good old Turbo charged Alloy V8 engine & box into it, 350hp + Am i really insane or what??????? cause i think it would work ok, don`t you????? ![]() |
Author: | sports850 [ Tue Aug 29, 2006 12:46 pm ] |
Ok , there are two things you're asking here Matt , would it work ? ![]() ![]() Would it be practical ? That depends on whether you would like to have traction at any stage of the khana .... I can see it being great for anyone lost and running late , all they'd have to do was look for the huge collumn of tyre smoke from your run and they'd find the course ![]() ![]() ![]() |
Author: | cush [ Tue Aug 29, 2006 12:48 pm ] |
yeah... who needs a gearbox anyway. ![]() |
Author: | TheMiniMan [ Tue Aug 29, 2006 12:52 pm ] |
The gearbox is underneath the donk, it`s mounted to an Austin 1800 box ![]() ![]() ![]() should i use the R1? or should i use the Turbo V8? Or,,,should i just build both? |
Author: | Harley [ Tue Aug 29, 2006 12:59 pm ] |
Just put one in each end! ![]() |
Author: | TheMiniMan [ Tue Aug 29, 2006 1:00 pm ] |
I`m allready thinking about that, seriously!!!!!!!!! am i insane or is this line of thinking quite normal? Please tell me i`m ok!!!!!!!!!!!!!????????????????? ![]() |
Author: | richarde [ Tue Aug 29, 2006 1:02 pm ] |
I think both of the options would lack traction, although it depends how big and wide the tyres are going to be. I think it would probably just be better to go for the R1 engine because it is lighter. You can always give it an upgrade later if you feel it needs it ![]() |
Author: | Mike_Byron [ Tue Aug 29, 2006 1:15 pm ] |
Saw a homemade go kartand my friends workshop. Its a sort of buggy thing but it has quad bike wheels and tyres on the back, driven by a 250cc, 5sp Yamaha and an incredibly narrow track. No engine cut out system if the throttle sticks. Looks like small boat trailer wheels on the front and a single cable operated disc on the rear axle. My friend was on the point of refusing to work on it - had computer/ignition problems - because of the potential for someone to die in it. Just the sort of thing you wouldn't want to hit a stump or rock in while high speeding across a paddock. |
Author: | Smokie [ Tue Aug 29, 2006 1:43 pm ] |
Quote: am i insane or is this line of thinking quite normal?
What is sanity anyway TMM?? I find it is only my insanity that keeps me sane... ![]() All I will say is make sure you have a real big, strong rollcage on it... ![]() |
Author: | cush [ Tue Aug 29, 2006 1:47 pm ] |
but no seatbelts... ![]() |
Author: | MrBob [ Tue Aug 29, 2006 1:48 pm ] |
If you're going to make it FWD with a limo in it I hope your young bloke (or you for that matter) has big arms!! |
Author: | Smokie [ Tue Aug 29, 2006 1:53 pm ] |
No seat belts required as I am sure the driver will have a death grip on the steering wheel anyway... |
Author: | Miniless [ Tue Aug 29, 2006 1:58 pm ] |
I'll have 3 thanks |
Author: | dove grey 64 [ Tue Aug 29, 2006 2:37 pm ] |
mid mounted turbo charged R1.........hhhhmmmmmmmmm twinky 16v A+.............hhhhhhhhhmmmmmmmmmm |
Author: | Betty [ Tue Aug 29, 2006 2:42 pm ] |
you're a little bit insane (ok, maybe a lot) but that beast seems like a sh*t load of fun ! ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
